6431Views7Replies
Author Options:
I'm looking for a high volume, small size air compressor but I can't find a good one. What do you guys recommend? Answered
I need an air compressor that has an EXTREMELY high CFM (Cubic Feet per Minute) rating. It is for an air-powered exoskeleton (crazy idea, I know). It needs to be pretty small, backpack sized if possible, It doesn't need that big of an air chamber (fire-extinguisher sized). Continuous run is a must. Powering it shouldn't be a problem because I will be carrying ~ 30 pounds of Li-ion batteries for running the compressor. I also won't be needing more then ~ 100PSI. Weight is an almost non issue, I wouldn't mind a 20 pound compressor, I'll probably remove the frame anyway, so that will take away some weight.
bowmaster
bowmaster
Answer 10 years ago
I think I might get this: http://www.aircompressorsdirect.com/Jenny-GC5A-60V/p3829.html And slice off EVERYTHING and just keep the compressor and safety release valve.. Replace the motor and tank with something closer to what I need.
steveastrouk
steveastrouk
Answer 10 years ago
The one  you highlight don't run on DC, and needs 3.7kW to run it. Few people realise that compressed air is very  expensive to make.
Removing the receiver is really going to put all the effort you need on the compressor, and it won't get the rest it would normally get.
Hydraulics is the way to go. The pump would be pretty tiny.
Steve
bowmaster
bowmaster
Answer 10 years ago
I was thinking about that, but hydraulic systems are too stiff.
steveastrouk
steveastrouk
Answer 10 years ago
What do you mean by "stiff" ? To me and Nacho that means "controllable" and "precise"
bowmaster
bowmaster
Answer 10 years ago
By "stiff" I mean not good for a form fitting exoskeleton. If it's for something like the Raytheon Sarcos exoskeleton, that's fine. But I'm looking for something closer to the Crysis Nanosuit. I don't having a large backpack, but I don't want to lose flexibility.
NachoMahma
NachoMahma
Answer 10 years ago
.  I agree about going hydraulic. The overshoot and "ringing" of a pneumatic system would make gross movements difficult.
