1314Views15Replies
Author Options:
I'm looking for a way to transmit a metronome across a football field for band members during marching season? Answered
Plug a metronome via 1/8 inch plug into something and then listen to it on the other side with headphones.
peach_fart
peach_fart
10 years ago
for drumline rehearsals we plug our met into a long ranger and point it at the ground. during marching season we used p.a. system speakers. the long ranger at the ground gets rid of a lot of echo, but the p.a.s had an echo, but im not sure if you could mistake the tick and the echo at the far corners of the field, as i had it blaring in my face because i was in pit.
SeMi_AuToMaTic
SeMi_AuToMaTic
Answer 10 years ago
Yeah, our Highschool just uses the auxiliry input for the long ranger.
dab2000100
dab2000100
11 years ago
im a band member and im sorry but you will have to get that band watching the drum major and listening to each other,they should be able to distinguish the first beat from the echo.take it from me,my band is the florida state marching champions class 5A(AAAAA)and the drum majors should be good enough to mark times with each other
caitlinsdad
caitlinsdad
11 years ago
Can you just set up a strobe light a certain color that flashes to the beat? A visibile signal might work if they can see it on and off the field.
NobodyInParticular
NobodyInParticular
Answer 11 years ago
I agree. Xenon strobe lights on the sidelines seem like a much cheaper and more reliable way to get the signal across the field than by giving everybody their own radios or metronomes. (Ebay shows small party strobes for $15 and a used one for $6) The only downsides I see are the light being too far away or someone in the band being epileptic or blind.
starboyg
starboyg
Answer 11 years ago
Would I be able to set the strobe light up to a certain bpm?
NobodyInParticular
NobodyInParticular
Answer 11 years ago
I'm not sure that yours would come with BPM markings on it, but it would have a knob to control the rate. You could glue a large disc (CD?) to the knob to make it easier to control precisely, then experiment a little and make your own markings. Another possibility would be to interface a metronome with the trigger circuit on the strobe. I can't advise with that.
norsehorse
norsehorse
Answer 11 years ago
Do you use field commanders? Field Commanders= Strobe light but human.
norsehorse
norsehorse
11 years ago
If its for practice then use it loud through a P.A. system. Do you use it while you are doing the actual show? Or just give the field commanders each metronomes so they can keep the beat and the band can watch them more closely.
11010010110
11010010110
11 years ago
first amplify the sound with computer speakers and the like then connect it to a bunch of 3.5 mm splitters and extension cables that go to where needed headphones with integrated volume control may be needed. keep the volume of the amplifier on the max and turn the headphones volume down so they dont load it much (if its too much loaded some phones may not get nough power - especially if they are not identical or cables are really long) radio txmitter may be solution too if it can be clearly recieved without other noise in the background
randofo
randofo
11 years ago
You can transmit using a small FM transmitter (maybe 1 watt... maybe a little less...) and then have everyone in the band get cheap $5 FM radios and wear ear buds.
starboyg
starboyg
Answer 11 years ago
Will they transmit far enough? It needs to be able to go across a football field.
randofo
randofo
Answer 11 years ago
A 1 watt transmitter should roughly broadcast 1 mile. Anything over 1 watt usually requires a license in the US. You should check with local and federal laws an regulations.
coerul
coerul
11 years ago
The band director at my old high school just attached a digital metronome to big speakers, I think. A 1/8 inch plug might work as previously mentioned. A quick and dirty solution is to put the metronome up to a megaphone or other sound-projecting device. If it won't make that awful screechy interference noise.
starboyg
starboyg
Answer 11 years ago
We already have the speakers and it isn't a really good way outside. It echoes and the band doesn't follow it anyway. I wanted something for the drums to have and the drum major so if the two of us are right in time, everyone else will be.
