106Views6Replies
Author Options:
I'm looking into making moulds does anyone know the best place to get large amounts of epoxy gel and hardener?? Answered
jamjar15
jamjar15
8 years ago
thanks again guys for the suggestions! i chose carbon as for one it is a very popular strong material and im in the experiment phase for production as i hope to use the material in my art pieces in uni at some point in the near future :) cheers!
Jack A Lopez
Jack A Lopez
8 years ago
I recall seeing large amounts of epoxy used in this picture
https://www.instructables.com/image/FAF4S63E41EP280OTN
in this instructable
https://www.instructables.com/id/DIY-1000-watt-wind-turbine/
in Step 1.
But of course the author doesn't mention where he got it from
Authors do that all the time because they assume that every material they use is something so ubiquitous that it is available to anyone, anywhere on Earth.  Moreover the jargon or brand name by which the authors know/buy this material is the only name by which it is known.   What do you mean you've never seen product X ?  You know, you just go to the store and buy it.  Duh.
rickharris
rickharris
8 years ago
If it's Carbon Fiber you wanting to lay up I would make the pattern out of wood. Seal the surface well and use a mold release agent.
You need to approach a bulk supplier.
Unless there is some other underlying reason I would go for Fiber glass rather than carbon - It's easier to use and no vacuum bagging needed.
rickharris
rickharris
8 years ago
Your question is a bit vague - Google your local supplier of Bulk epoxy.
No idea where you are or what you actual need is. Epoxy is expensive,
Mold making is generally done with a flexible or semi flexible material such as silicone.
https://www.instructables.com/id/How-To-Make-Your-Own-Sugru-Substitute/
jamjar15
jamjar15
Answer 8 years ago
hey rick thanks for the reply appreciate it big time although I'm looking to get some kind of resilient hold as I'm having a go at making wings for my civic in carbon fibre but the kits you can buy only have enough epoxy gel to make an A3 size and i need at least enough for 2 A2s if you see what i mean now.
steveastrouk
steveastrouk
Answer 8 years ago
Doesn't it crack in thuck sections too, from the exothrrm?
