179Views3Replies
In regards to Slime, what do you think about this idea?
I have been using Slime for almost 2 years. This will be my first Arizona summer using the stuff. Last summer I was in the humid southern states cycling with no problems until I returned to Phoenix. When my tube could hold no air at all, I replaced it. Later, I needed the rubber and cut it open to find that the Slime turned to dust.
Now, it is getting warm again and I started to have a slow leak. I simply added more slime and the problem was solved. After the fact, I came up with this idea:
Since Slime is water soluble and it keeps drying out, can I just add water to it?
It is likely that I will try this out soon enough but I was curious to any input.
Thanks
Best Answer 10 years ago
Look into really nice commuter tires like the Schwalbe Marathon, or Marathon Plus. Lots or people report several hundred to several thousand miles without a flat. If you want to test the slime, lay a sheet of glass in the sun with a layer of slime on it. When it dries, scrape it with a razor blade and try to reconstitute the powder. If it clumps, call the myth busted ;)
10 years ago
. The factory says no. For more info, see the Slime web site.
Answer 10 years ago
I could not find it. Also, of course they would say no!
