72Views3Replies
Individual volume on computers
I was wondering. Is it possible, with or without hardware so I can browse the internet without volume, for listen to music at the same times on Itunes, and hear it. Basically, is it possible to not here sounds on the internet without turning my whole computer volume off?
Google was no help.
11 years ago
Found it here: http://contests.about.com/od/technicalassistance/ht/turnoffsounds.htm
Strange, I never really needed to do that before! You learn something new every day.
Here's How:
Open Your Control Panel
The easiest way to open the Control Panel is to click on "Start" and then click on "Control Panel."Open the Internet Options
Double click on "Internet Options" to open that section of the Control Panel.Select the "Advanced" Tab
The Advanced Tab is usually on the far-right side of the Internet Options screen.Scroll Down to Multimedia
Scroll through the options until you see the section called "Multimedia."Deselect the Play Sounds Option
Click to un-check the option called "Play Sounds in Webpages." This will turn off all sounds in your internet browsers.Turn Sounds On Again When You're Finished Sweeping
If you would like to resume listening to sounds on your internet browser, be sure to follow these steps again once you are done entering sweepstakes, and check the "Play Sounds in Webpages" option once again.Reply 11 years ago
That doesn't seem to work. I noticed it said this applied to Internet Explorer. I use Firefox. Do you know anyway that I could do this on Firefox?
Reply 11 years ago
How to disable sound in Firefox?
One of the more common questions I receive to my answerblog is How do you disable (background) sound in Firefox, a question I have always been tempted to answer with “By installing Opera, where you can turn embedded sound on and off whenever you feel like it”.
However, there is an answer: Adblock can block files by type. Add the following to your Adblock:
The answer to this was found in the LiveJournal Mozilla Community
