10388Views11Replies
Author Options:
Infrared Sauna wiring? Answered
Well, I bought a used infrared sauna the other day for real cheap because it "just stopped working all at once". Figuring its just a fuse or something, I took it. Well now I cant figure it out for the life of me.What seems to be the problem is that no power is getting to the primary transformer. That would be on the second small circuit board to the right. It is getting to the secondary transformer fine. Heres a pic of whats goin on. Those things on the sides are fuse holders, (no not burnt out).
iceng
iceng
9 years ago
What you call the primary appears to be a AC to DC converter module
the red and black wires are output DC.
Reading between your lines, one of the converter driving power
switching transistors has failed.
The lower circuit which we can not see may have useful info to help
your cause.
A
gtsixeral
gtsixeral
Reply 1 year ago
i know this thread is very old but i have the same issue with mine. what should i be looking for as far as testing parts on the AC to DC converter module?
LiquidLightning
LiquidLightning
Answer 9 years ago
Gotcha, i'll get pics in a bit. You are correct about the black/red. Those should output 12v DC, but they output 0. That is the whole problem, either that module failed, or power is not getting to it.
SunsetS1
SunsetS1
6 years ago
OK, well to start with, I see that this was posted approximately 3
years ago... so perhaps I cannot help the original poster of this.
To
determine whether it is the main board or not, based upon the picture
above, first unplug from the wall. Next, move the left two wires (BLUE
AND BROWN) to piggy back the right two, making sure to keep the brown
together. It probably won't matter if you get them mixed up since they
are AC, but maintaining the color code is a wise practice. Plug back
into the wall.
If the sauna comes to life again, the problem is the main control board.
If
the sauna remains dead, it is the 12v DC power inverter board which is in the top
right of the picture and is incorrectly labeled "Primary Transformer
Board."
That said, the problem with this style of control system is most likely the main circuit board itself.
Our company has been rebuilding infrared sauna control systems for the big
retailers and dealers for more than seven years, and the failure in this
post is a really common one.
We offer a customized DIY repair kit, or you can ship the whole unit to us for a professional rebuild.
We rebuild these all the time, and our 5 yr. warranty is the best in the industry.
Feel free to contact us at: sunsetspas@gmail.com
Or call our office at: 660-263-0984
Ask for John.
gtsixeral
gtsixeral
Reply 1 year ago
how can i get the diy repair kit?
CarlaMW
CarlaMW
Reply 1 year ago
Hey there I don't know if you'll get this. But it seems like you know what you're talkin about when it comes to the sauna repair. I too, bought a used one. However, it's been fantastic up until 2 weeks ago. I've used it for more than three years consistently with clients. As of a couple weeks ago, the timer on the thermostat was not counting down. When it did the beeping wouldn't stop when he got to zero. I would unplug it and reset it and it was fine now, as soon as I plug it in it makes that alarming continuous loud beeping noise. All the heat works but I believe it's somewhere in the thermostat or something. If you could offer any help resistance, please do
BlakeC37
BlakeC37
Reply 2 years ago
I'm following along to this as well - same situation, bought a used Sauna and same issue. I verified the same findings as the original poster..... I piggy backed the blue + brown wires to the wires on the right (brown + red).....a soft clicking (as if it was a relay) emmitted from the board ever couple seconds.... the control display did not light up, but when I hit on/off button I could again hear a soft click as if it wanted to start up.
I will also send you an email and hoping you can help with either a new power supply or DIY repair kit.
SunsetS1
SunsetS1
Answer 6 years ago
Not sure why the text formatting in the above post is screwy... it was right the three times I reposted it to try to correct that issue.
dirtnap.inc
dirtnap.inc
2 years ago
I am having a very similar issue with my sauna to this one and my wiring looks similar as well.
In the White Circled area of my attached photo - when I "jump" the red to the second brown as described in the original post I get power. So according to John I have a problem with the main control board. If that is the case, what do I replace to get it working again?
Hoping someone can help!
Thank you
Dave
canucksgirl
canucksgirl
9 years ago
We use saunas in our family (we're all originally from Finland), but we don't have infrared saunas... I showed a family member your question, (they've told me to tell you to), test the thick red primary wire (on the right), by using another one from board to board, to see if thats the issue. If that still doesn't get power moving, then you may have a problem with the power board itself. He said to then remove it and check it for any obvious signs of a problem. If the new wire gets power flowing to the primary board, but the unit still fails, then the primary could be the issue, or another problem could exist on that board. You'd need to then remove it and look for signs of any problems.
I hope that helps. (Sorry for the 3rd party message). :)
LiquidLightning
LiquidLightning
Answer 9 years ago
Right, forgot to mention that the green blocks are the output power from transformers, not input. The blue brown brown red are the input power.
canucksgirl
canucksgirl
Answer 9 years ago
Hopefully you can detach the boards and get photos from the underside... there's plenty of members here willing to help. :)
rickharris
rickharris
9 years ago
Test continuity of the cable in from the mains. Go from Plug to terminal on transformer. If no continuity the work back to find the break.
Don't assume the plug is OK.
LiquidLightning
LiquidLightning
Answer 9 years ago
Which plug? From the wall AC power?
rickharris
rickharris
Answer 9 years ago
Yes the AC plug. This way you know if the electricity is getting to the board or can isolate why not.
