862Views13Replies
Author Options:
Intel Galileo will not communicate with Uno? Answered
Hello,
I want to communicate with my arduino uno via serial on pins 0 and 1 of the Galieo and SoftwareSerial on Uno pins 10 and 11. I have checked the baud rate and all i get when i read the SoftwareSerial port is garbage. Does anybody know why this is happening?
Thanks
iceng
iceng
6 years ago
Are you inadvertently sending inverted signals ?
Are there the proper number of stop bits ?
Are you using a parity bit ?
Are you sending 8 bit or 7 bit ASCII ?
Are you sending Hex or Binary ?
A
D5quar3
D5quar3
Answer 6 years ago
I am using Serial.print() on the Galileo. I have even tried Serial.read() on the Uno connected to pins 0 and 1. Still coming up with nothing
iceng
iceng
Answer 6 years ago
No scope and you don't know about party, polarity or stop bits is a tough sit.
Try feeding Galileo to Galileo or Uno to Uno if you have two of either.
BTW did you try reversing pins 11 & 10 or 1 & 0 in case you are sending to a sending line ?
D5quar3
D5quar3
Answer 6 years ago
I have two Galieo's but not Uno's but I can't write the read on the same serial port, so I don't know how I can test that.
iceng
iceng
Answer 6 years ago
Test the Galleo's send G(a) to G(b) ..
See if you can get ASCII from one to the other.
This will confirm the Galleo's are working or not.
Right now you don't know if the Galleo's, the Uno or you are not working.
Prove the Galleo's work also shows you do too.
iceng
iceng
Answer 6 years ago
Set one G to send and set the other G to receive connect the two ports
Tout(a) >> Rin(b) and Rin(a)<<Tout(b) for both lines and ground.
D5quar3
D5quar3
Answer 6 years ago
Aren't pins 0 and 1 the same as the USB client? How would I be able to see what is being communicated between the two?
iceng
iceng
Answer 6 years ago
If you are using USB already madeup cables I would look for a way or cable that flips the transmit / receive lines. Or maybe there is a way to invert port lines on the Ono pcb.. Steve uses the Uno he may know..
How did you know G was not talking with Uno ?
Obviously, write a routine to send, any of the received data to a small LCD !
D5quar3
D5quar3
Answer 6 years ago
I was writing the input of SoftwareSerial to the serial monitor with the Uno, and I'll try to find an LCD. I don't think I have one. I was using an LED to test the output...if char == 1 then light the led...but no luck.
steveastrouk
steveastrouk
6 years ago
Get an oscilloscope and look at the signals. Are the Galileo and Uno voltage compatible ?
D5quar3
D5quar3
Answer 6 years ago
I do not have access to an ocilloscope. Yes they are both 5v systems
steveastrouk
steveastrouk
Answer 6 years ago
A "true" nerd needs access to an oscilloscope......
Try Iceng's trick of reversing the connection to one of the serial ports
D5quar3
D5quar3
Answer 6 years ago
I have switched the lines and messed with the baud rates
