100Views6Replies
Author Options:
Interfacing a robot with landline phones? Answered
What i would like is that i have an answering machine at home that starts after a certain amount of rings. What i want is that when the machine answers the robots listens in and waits for a certain sequence of keys to be pushed. It will then send the tone 1 down the line and somehow i would also like the cal to be ended(but that isn't necessary).
kevinhannan
kevinhannan
Best Answer 11 years ago
there is some software that can do this. essentially you have a modem enabled laptop/pc and plug your phone into that. a call is rcd, the pc counts the rings, answers it with a message, you listen to the message menu and press your key/s as rqd and the software detects those tones and then takes the action you specify. It's been years since I used software like this (about '95), but if you search for something like telephone / telecomms automation software you might get lucky. You could even get a seriously old pc to do this for you - then I was using Win95 with a 10Gb hard drive and 512Mb RAM and lowly pentium. Once you have this set up you can even ditch the monitor. You could pick this up for less than £30. however, the software is designed for industry and so is not cheap.
wee_man
wee_man
Answer 11 years ago
Oh that sounds interesting. Funny thing i have a Petium 2 that i could do this with. I go google! Thanks Also thanks everyone else for posting
kevinhannan
kevinhannan
Answer 11 years ago
I did see on www.download.com there is some free/trial software that will do the job I wrote about earlier - have a look.
steveastrouk
steveastrouk
Answer 11 years ago
Unless you are on the same exchange, the chances of the number of rings you "hear" and the number of rings the called number "hears" agreeing are fairly remote I am told.
kevinhannan
kevinhannan
Answer 11 years ago
you are right, and it is not even with the same exchange. each telephone device has its own timing circuit and ring-tone. however, that said, when I have my fax-modem on to rcv faxes after x rings, it is usually accurate, but the above statement remains true.
lemonie
lemonie
11 years ago
What do you want to do with this? Much of what you say can be handled by a fax modem. If you dial it up it will answer, it will send a tone, hang up and the call ends. L
