324Views2Replies
Is a brita carbon water filter in its original case with holes on both sides, is it safe to breath true?
Good evening community; my question regarding the construction of a gas mask, mask is done and my filter is a brita carbon water filter in its original case with holes on both sides, is it safe to breath true this water filter. thanks in advance.
https://www.vacuumgenie.co.uk/brita-maxtra-plus-single-water-filter-cartridge-1025352.html?gclid=EAIaIQobChMIx-Dh18jH5gIVWeDtCh3GFwgkEAYYAyABEgJaPvD_BwE#.Xf5-2mTVKpo
1 year ago
Yes it is safe to breath through.
I don't know how effective it would be for the use you intend it.
The chunks are large enough for air to get around.
1 year ago
I think the phrase you want is,
"safe to breathe through"
rather than, "safe to breath true"
I'll leave it as an exercise, for the interested reader, to look up those words in a dictionary.
https://en.wiktionary.org/wiki/through
The part I am wondering about is the adapter. I mean, where is the adapter that adapts the funny shape of that Brita(r) brand water filter, to something you can wear on your face?
Maybe you have not built that part yet.
Anyway, my main concern is the question of how fast air can move through that water filter cartridge, and is that fast enough for safe breathing?
So, in the event you build a mask to fit this filter, I suggest you test it out with friend nearby. The reason why you want a friend nearby, is because you are going to instruct your friend to remove the mask from your face, in the event you loose consciousness.
The reason why you have to do it that way, is that you do black out from lack of oxygen, you will not be able to take the mask off yourself.
By the way, if you are looking for a contrivance to filter bad air, for to make it more breathable, there is something called a, "respirator" or "respirator mask" or similar, sold in hardware stores. It will usually be in the same aisle with the gloves, and safety glasses, and hard hats, and other PPE (personal protective equipment).
https://en.wikipedia.org/wiki/Respirator
https://en.wikipedia.org/wiki/Personal_protective_...
Wikipedia also has an article for "Hazmat suit"
https://en.wikipedia.org/wiki/Hazmat_suit
and also "gas mask"
https://en.wikipedia.org/wiki/Gas_mask
Again, I will leave it as exercise for the interested reader, to figure out how those topics are similar or different.
As another BTW, if you want a way to test a activated carbon air filter, to test if it is working, there are a number of easy to find, substances that produce a strong, recognizable smell, e.g. garlic, vinegar, menthol, that is also easily adsorbed onto activated carbon.
I have seen a list of these substances, or odors of the same, in a PDF titled, "Activated Carbon Capacity Index Chart".
https://duckduckgo.com/?q=activated+carbon+capacit...
It is not really a chart. It is more like a list, and I am not sure of the sources for it, or how reliable it is. It was probably written by someone who sells activated carbon. You will recognize this list by its vague and colorful entries, like "cheese", "body odors", "gasoline", next to more chemical sounding names like, "butyl acetate" and "dichloroethane"
1 year ago
If it is for fun then no problem, if it is for actual use as protection don't do it.
A gas mask needs a filter that is fully sealed and won't let any unfiltered air through.
Water filters are designed to work under pressure while a filter for breathing maks is designed to allow a very flow of air.
After all, you neither want to struggle to get air, nor risk getting unfiltered air.
It is quite easy to make your carbon filters from scratch.
Wouldn't recommend them to test tear gas or chlorine but for what you encounter in your workshop it will be fine.
