102Views3Replies
Author Options:
Is a toggle switch necessary for this USB Solar Charger? Answered
Hi all! I am a newbie with a simple question. In the instructable below, is the toggle switch necessary or just a design feature? I thought the circuit would only be complete once the USB device is plugged in, acting as the switch so to speak? It is a 6V solar panel to 3 AA rechargeable batteries, then to a DC boosting converter with a 5V USB output.
Also, a big thanks to Joshua Zimmerman. Love your instructables!
www.instructables.com/id/Solar-USB-Charger-20-21/?ALLSTEPS
steveastrouk
steveastrouk
Best Answer 7 years ago
His circuit is incorrect. The item at the right hand side is a USB charger MODULE, not a USB connector. So unless you have the switch, its always "on", it may not draw much current if the load USB isn't connected, but it may draw SOME.
Stevemills04
Stevemills04
Answer 7 years ago
Thanks for your reply Steve. So the item I have is a "Step Up DC-DC Boost Converter 3V to 5V 1A USB Charger", the same as the red one in his instructable. Are you saying the switch is a good idea to prevent the USB module from having a current draw when not plugged in? Is there an alternate way to avoid the loss without using a switch? Thanks again for your help, is it appreciated.
steveastrouk
steveastrouk
Answer 7 years ago
You could try it without the switch, and measure the current draw when there's nothing being charged - I may be wrong, it might be microamps, and ignorable. Otherwise, unless the step up wotsit you have actually has a shutdown or sleep pin, you'll need a switch,
