355Views1Replies
Is it OK to mix through hole LEDs with surface mount resistors?
I was wondering if it's OK to use a surface mount resistor;
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P1.0KECT-ND
with a through hole LED;
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=C503B-RBN-CX0Y0AA1-ND
I've never worked with surface mount components before and don't know if there's any special instructions with their use, ie: are they more susceptible to heat, that kind of stuff. I want to keep it as small as possible but would I be better off using through hole resistors like these;
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=1.0KQBK-ND
Again, that you all for your help.
Best Answer 11 years ago
So long as you take care to allow for the power handling of the resistor, there's no real problem. Use a fine tip iron, or use solder paste and a hot air gun to set the components - once you start using SMT, you get really attached to the process ! Steve
