745Views4Replies
Author Options:
Is it better to use a single or double glazed panel for a flat panel solar water heater?? Answered
Re-design
Re-design
Best Answer 10 years ago
Unless it's cold outside then I can't see any reason to use double glazing. It may even cut down on your heat transmission.
On the other hand I could be wrong it's been a long time since I worked with solar panels.
kwbanks
kwbanks
Answer 10 years ago
Many thanks
frollard
frollard
10 years ago
Redesign has it right - you want maximum light transmittal and good heat (infrared) insulation. Light goes into the solar heater, heats stuff up, and is radiated off the black objects as infrared heat. Infrared bounces off glass, thus a greenhouse is made. Double glazing reduces the initial input slightly, but would help insulate from heat loss in a cold environment. 6.5 of one, half a bakers dozen of the other.
kwbanks
kwbanks
Answer 10 years ago
Many thanks for your comments.
