429Views4Replies
Author Options:
Is it okay to use a hot glue gun to keep a braided cable in place? Answered
Is it okay to use a hot glue gun to keep a braided cable in place? If not what is a safe way to keep it attached?
seandogue
seandogue
4 years ago
Hot glue may compromise some softer more flexible insulation types. There are specific mounting adhesives used in professional settings, but clear silicon or RTV works quite well, although it take a while to setup.
Downunder35m
Downunder35m
4 years ago
In place where and how exactly?
A lot of things work, including heat shrink tubing...
AnthonyS264
AnthonyS264
Answer 4 years ago
I'm making a charging stand with wood on a CNC router, so I cut out a pocket in the material where the wire will feed and was wondering if it was a good idea to hot glue the wire so it doesn't fall out or get pulled out when I'm using it.
Downunder35m
Downunder35m
Answer 4 years ago
Why not hide them completely?
Was thinking of cutting a groove into the wood, secure the cable in there and fill will a mix of sawdust and wood glue.
iceng
iceng
4 years ago
Tie wrap 9&10, Shrink tube 7, Spiral Hose 4&5, Wire Sleeve 8, cable trays 1, cable clamps 2-3-4 and not shown Zipper sleeves. Not counting twine.
Beware ... high temperature TEFLON insulated wire bundles can cold flow if crossed and pressed together >>|:| << and can short in a few months.
All these products need a bit of knowledge to be lastingly used...
As an example clear tie wraps die in two years in the sun use the darkest colors.
I will braid wires before using a hot glue gun which can melt in summer under heavy current.
Wire-Basket-Cable-trays.jpgClamp.jpgClampSize.jpgHanroot-Plastic-Wall-Nail-Nylon-Cable-Clips.jpgSpiralHose1.jpgspiral-hose2.jpgShrinktube.jpegBraided-sleeve.jpgTieWrap Nylon1.jpgTiewrap2.jpgWiresnap1.jpg
