3112Views7Replies
Author Options:
Is it possible to make batch files take fractions into account? Answered
When you put a command to evaluate and equation, like (2/3)+1, the answer would just appear as 1. Even when you put an equation like (2/3+1)*3, where the answer is an integer 5, the answer would come out as 3. Any idea how to make batch files calculate the fractions together with the integers?
Tags:batch
Aosih
Aosih
11 years ago
Multiplying it by 1000 is a great idea! I'll think of a way to put it into the batch... I was trying to get the batch to calculate something for a game... The game goes like this... Pick 4 numbers from 1-10 (numbers can be repeated)... Using each number once (not more not less), and using only + - * /, we have to try and get the number 28... Some combinations are impossible though, so I was trying to make a batch which can calculate if it is possible to get 28...
lemonie
lemonie
11 years ago
Batch files run batches of commands they don't do math. What command are you using for this - (exact specific line) L
lieuwe
lieuwe
Answer 11 years ago
yes they do, i believe that with set /a abc=equation you can do math, i don't think that it takes fractions into acount, but you can just have an imaginary dot, like instead off 129.3664 you use 1293664....
lemonie
lemonie
Answer 11 years ago
That is running the SET command. You can put the SET command in a batch, but being in or out of a batch is irrelevant here. The question would have been better titled "Is it possible to make the MS DOS SET function take fractions into account?"
L
Jayefuu
Jayefuu
11 years ago
If you tell me what it is you want to do I'll do it for you in Perl or Python.
AlternateLives
AlternateLives
11 years ago
I would try using whole numbers that are larger than the numbers that you are using (for example, instead of 29.99 you use 2999) and then divide by 1/100 (in this case. add 1 zero for every number behind the decimal.)
Jayefuu
Jayefuu
11 years ago
What're you trying to do with your batch file?
