1185Views2Replies
Author Options:
Is it possible to use a 4017 ic to controll a bipolar stepper? Answered
I want to build a robot. i have got two bipolar stepper motors but my micro is 2 outputs short of enoght so i was woundering if i could use a 4017 taking a pulse from the micro then driving transistors on the outputs connected to the stepper.
bayhoecott
bayhoecott
Best Answer 11 years ago
Yes no problem. It will only drive the motor in one direction  though. I have such a circuit running fine on my breadboard at the moment. It did not like the 1n4001 diodes to protect the 2n4001 NPN transistors I was using (suspect it needs a higher voltage rated diode). You need a 1.5k resistor between the first four outputs and the transistors. Dont forget to feed the output 4 to reset. You are only using it as a ring of four by doing that. It would be far better to use logic level mosfets (fully protected ones best) on the  4 outputs, you can get them for peanuts these days.  You can make it reversible but if you really want that you are better off using a bi directional 4 bit cmos shift register. The results are remarkably good even with a simple circuit. The manufacturers of dedicated stepper motor ics are not worth the time of day they produce one day and stop making them the next so thats why I dont touch them with a barge pole.  The 5804 which was about $1 now sells for $40 a piece because they have stopped making the damn thing.
steveastrouk
steveastrouk
11 years ago
Why ? You could just use a dedicated stepper driver IC - these usually only need a direction and step signal - 4 pins for two stepper motors. Steve
