170Views3Replies
Author Options:
Is it possible to use a ROUTER or HUB with standart batterys Answered
Is it possible to use a ROUTER or HUB with standart batterys like this:
http://itp.nyu.edu/physcomp/uploads/battery_alkaline.jpg
what kind of modifications has to be done..
madirfan
madirfan
9 years ago
Ok here is the thing what i wanna test:
i have this Swicht..
LevelOne FSW-0811
http://www.level-one.de/prod/7008/FSW-0811.htm
i just need the LED funktion.. meens.. if i stick a RJ45 corss over cabel that
i get the LED opend..:D
i wanna make this
https://www.instructables.com/id/RJ-45-key-chain-and-rack/
and wants to add in my switch..
i hope you get the idea..
thegeeke
thegeeke
9 years ago
You could... but why would you want to? You don't want any down time on a router or a hub... including when your batteries go dead! :)
mpilchfamily
mpilchfamily
9 years ago
Yes you can run most routers off batteries without any changes unless the router has a power supply built in rather then using a power brick. I believe most routers run off 12V DC.
The power brick on my Linksys outputs 12V @ 500 mA. You'll need 8 D, C, AA, or AAA batteries to power a similar router. Keep in mind the larger the battery you use the longer it will last.
