4936Views29Replies
Is it possible to use an SCR to make a small solid state tesla coil?
From what I understand, an SCR is like a diode that can either be turned on to act like an everyday diode, and it will only turn back off when the power is cut. With this understanding, will this circuit work? if not, can you explain? even if it doesn't work as a tesla coil, will it work as a fence charger (with a trigger transformer or ignition coil?)
Best Answer 8 years ago
SCRs turn off when there is no current through them, or no voltage across them.
Answer 8 years ago
that's what I meant by "when power is cut" to them. well at least I understand there operation correctly.
Answer 8 years ago
That's not correct, they can be switched when power is still applied to them, but its tricky.
Answer 8 years ago
So then what am I misunderstanding, when power is cut to the SCR itself, when there is no voltage across it. (without the capacitor) and no current flows. I don't mean the entire circuit. if they can be turned off while current is flowing, how is it done? Just with a brief "blackout" of power?
I read somewhere where that older SCR's require backwards current at the gate to turn them off again. (also, are SCR's and Thyristors the same exact thing?)
Answer 8 years ago
Be careful talking of "power", SCR (same as a thryistor) are current controlling devices. If you can very briefly blip the anode to cathode current to zero, then they turn off. Its back in the mists of time I actually studied these things, but see if you can find schematics for the McMurray inverter, if you're interested in SCR commutation.
Steve
Answer 8 years ago
I took apart a switching power supply and inside was an MCR72. I played around with the connections and I had it wired up to an LED. I then touched the gate to +v rail, and it turns on, and when I touched it to ground, it turns off. I though it is not possible to turn these off. Con you explain this please?
Currently I am trying to make a low voltage version of the above circuit. only problem is that I need something that will only conduct after reaching the specified threshold voltage. Will a zener diode work?
Answer 8 years ago
You're only tickling it. That's an 8A device. Get some load on it, and try switching it off.
Answer 8 years ago
will it pop? I currently have nothing that draws that much amperage at 12v.
Answer 8 years ago
Keep it heatsinked, and keep the current say at 1A - try a car taillight
Steve
Answer 8 years ago
I tried out the SCR on 9V with a flashlight bulb, and I wasn't able to turn it off by touching the gate to ground. but shouldn't that allow electricity to flow from the first PNP transistor to ground instead of the second NPN transistor and thus break the clamping of the SCR, like I did with 4V?
what would happen if I replaced the neon with either a zener diode (in reverse) or to the proposed circuit above? and what are some real world useful applications for this component? I never see much circuitry using them.
Answer 8 years ago
It wasn't the voltage that let the circuit work, it was the fact that the load was so low it wasn't actually latched on properly.
The reason YOU don't see circuits using them, is that you don't deal in high power electronics like inverters, phase controlled bridges etc etc. They are THE goto method in high power systems.
Answer 8 years ago
that's why I used a bulb instead of an LED... fore more current flow. this explains why I see then in older electronics and in high power stiff (like where I got this one from.. a ~100W switching power supply) thank you for your reply and stuff. Im going to try to build the above circuit with a DIAC and see what happens. Thanks!
Answer 8 years ago
In a 100W switcher, its probably there as a "crowbar" circuit. Look that one up ;-)
There are GIGAwatt inverters that rely on thyristors that look like trashcan lids.
Answer 8 years ago
I built a circuit with a drill motor, where a 3000 uF capacitor charges up though some small resistors, then discharges into the SCR. This creates a significant delay from the time voltage is applied to when the motor turns on. only problem is that the capacitor remains charged for next use, so cutting the power, it turns on instantly.
Is there something along the lines of an anti SCR, where it is on until a voltage on the gate is applied, then latches off?
Answer 8 years ago
No, but there are tricks to turning SCRs OFF when you need to - like I said, see "Mcmurray inverter" for some concepts. Its pretty heavy electronic theory - I studied it for my degree, a long time ago.
Answer 8 years ago
Thank you for your help. I built it using an ignition coil and now I have a good fence charger like circuit. I can't seem to get it to work with higher frequencies because the SCR will stay latched. I will continue work with this and see how far I can take it!
Answer 7 years ago
That's the gotcha with SCRs.
Reply 6 months ago
It's been so long! 1 degree later and I'm back to playing with power conversion again :)
I've been working on making a new half bridge PCB layout and am able to push around 1kW into my tesla coil now. Although my FETs are still failing periodically, I think it is from shoot-through from high dv/dt. This got me thinking again about using SCRs in such an application and I found my old question googling about it lol!
If I was to use SCRs in a half bridge, with freewheeling diodes to keep the voltage within bounds of the supply, then could it be possible to implement a resonant-mode controller (LC controller) with them? I would have to somehow ensure I always operate on the capacitive region of resonance (because of course I can't switch off SCRs at will, only when current crosses zero, transitioning to the freewheeling diodes before firing off the other SCR.) Switching losses are at the maximum for switch-on but SCRs are fast to turn on so meh. Switch-off occurs exactly at ZCS which is nice, no switching losses there at all.
Would this work? This was just a shower thought, My biggest question is if SCRs can operate successfully at up to 0.3MHz, or if they take forever to turn off (have some sort of forward recovery like slow rectifiers)
I'll be looking through the literature to see if it is common to build LC converters like this. (of which a DRSSTC tesla coil is one, right?) Just started looking into that McMurry inverter thing, it's hard to find ELI5 explanations for it, guess only the most advanced doctorate level power engineer researchers bother with things like that lol.
The end goal of this project is to have an audio modulated tesla coil, and I mean legit audio modulation, not interrupted single voice square wave monophony, down with probably a PLL to do PM or FM modulation and slope demodulation on the high Q secondary.
Answer 8 years ago
with either a zener diode or a DIAC or SIDAC? are SCR's, trisistors, triacs, diacs and TRIAC's and all part of the same family and often used together, (I often see them used in old-school technology)
Answer 8 years ago
OK then.
8 years ago
This kind of Tesla coil isn't solid state, it is called an off line Tesla coil (OLTC) I'm not sure if anyone has built one with a thyristor but it may be possible. (most are made with IGBT's, I'm building one at the moment.)
Here's a couple of links about them.
http://scopeboy.com/tesla/index.html
http://scopeboy.com/tesla/oltcfaq10.html
Answer 8 years ago
whats the difference between OLTC's and SSTC? other than that OLTC looks like a IGBT driver that is powered at mains?
Answer 8 years ago
A SSTC directly resonates the secondary coil by oscillating the primary coil at a set (calculated resonant) frequency.
Example: Say the resonant frequency of a secondary coil was 500kHz then a SSTC would oscillate the primary coil at 500kHz.
Whereas an OLTC will pulse the IGBT at most at 1kHz to simulate the effect of a spark gap on a traditional Tesla coil (but at a lower voltage), this means that an OLTC still requires the inductor/ capacitor resonant matching involved with traditional Tesla coils.
Answer 8 years ago
Yeah, I figured that out while looking down that article. what would it be called if the IGBT was driven at a variable frequency, that can be changed anywhere from 1khz to 500kHz?
Answer 8 years ago
The IGBT's are driven at a variable frequency but at 1Hz to 1000Hz, the idea is not for the IGBT to oscillate the primary coil but to let the tank capacitor discharge through it and let the tank capacitor and the primary coil do the oscillating like a normal Tesla coil but with the spark gap replaced.
Also I don't think there is any kind of IGBT that can oscillate at frequencies that high. There max is generally 2kHz (I think).
Answer 8 years ago
what I mean is if one were to build what I described, what would it be called?
Answer 8 years ago
I'm not too sure what NE2 is but if you were to drive the thyristor the way you describe and you make that capacitor tuned, then it will be an OLTC.
Answer 8 years ago
no, I meant the OLTC I described with the IGBT being driven at a very high frequency, with a tuned circuit. the NE2 is a neon light. They act like small capacitors until about 80V is reached when the neon will glow and act like an almost dead short.for a small circuit.
8 years ago
