126Views2Replies
Author Options:
Is the torque that an electric motor provides the same that is required to turn it when not powered? Answered
A 30 hp electric motor provides 158 ft-lbs of torque when rotating at a rate of 1000 rpm. Does the same electric motor require 158 ft-lbs to be cranked at the same speed?
Think of it as using any electric motor as an electric generator like in a windmill.
seandogue
seandogue
6 years ago
My best guess is no.
If loaded? Plus losses.
If not? far less torque should be required, since you're not dealing with back EMF
iceng
iceng
6 years ago
You want to know if that 30hp machine as a generator will need the same
158 ft-lbs at 1000rpm to generate an output of 22 KW ( 30 x 746 = 22380 W )
Yes it will !
BTW .... HP = Torque x Speed / 5252 = 158 x 1000 / 5252 = 30.08
steveastrouk
steveastrouk
6 years ago
If you want 30hp OUT of the generator, then yes, you need 158 ft-lbs or whatever to drive it at that speed./
