178Views10Replies
Author Options:
Is their a substitution for ball bearings in K'Nex guns? Answered
EDIT: I mean as in the true triggers and such
Tags:knex
Killer~SafeCracker
Best Answer 10 years ago
If you use gray connectors the correct way then I would say yes there are.
Furloy
9 years ago
definintly depending how good you are with modding/inventing triggers. you might be able to get away with a hinge of some sort.
happy new year!
Mr. Stealth
10 years ago
It depends what they are used for. If they function as separate parts together, like in a break action gun then no. If they are used as hinges, they you could use Knex hinges. Hope this helps!
DJ RadioMr. Stealth
Answer 10 years ago
you dont even need hinges for a trigger anymore.
knex_mepalmDJ Radio
Answer 10 years ago
Dj what non knex bullet proves the best? peas? 4 mm bbs?
rickharris
10 years ago
As ammunition? Dried peas, small lengths of dry spaghetti, small balls of aluminium foil.
