424Views2Replies
Is there a difference between a high pass filter with an op amp and a high pass filter without one?
I'm trying to modify a guitar effects pedal of mine to remove some squeaking and decided that a highpass/low pass combo with some potentiometers to modify the highpass and low pass points (since my pedal emits squeaking at different frequencies on different settings) and I was wondering if I should use a high/low pass with an op amp, capacitors, and resistors - or just a simple resistor and capacitor filter. Does anyone know if either configuration is a detriment to sound quality?
Best Answer 8 years ago
Its difficult to make a filter as flexible or as sharp as an ACTIVE filter.
Use decent op-amps and there is no degradation of the sound, if the thing's driven properly.
It sounds like you need to look for "parametric filter" designs.
Steve
8 years ago
They are basically the same except you can not easily add pots to a straight high-pass,
However you can with an Op-Amp because that has gain.
And there is no signal loss when using an Op-Amp, even with pots.
Walter Jung has a very good book on filters if you go to Amazon,
A.
