19536Views19Replies
Author Options:
Is there a positive and negative wire in the three pong computer desktop power cord? Answered
MirhashemZ
MirhashemZ
2 years ago
Excellent explanation! Simple, effective, and easy to understand - THANKS
Quercus austrina
Quercus austrina
9 years ago
Only if it is plugged into an outlet that supplies DC, in which case you would need to use a test device to determine the polarity of the wires. If the cord is to be plugged into a standard AC outlet, see the color code explanations elsewhere in these answers, but it is AC current , not DC. If you are just using the wire without plugging into an outlet (plug cut off), then I suggest using caarnted's color listing as it is industry standard, which will help keep confusion at bay.
(Please don't play with mains power - that which comes from a wall AC outlet - as it can kill, especially if you really don't know what you are doing with it.)
Qa
canucksgirl
canucksgirl
9 years ago
Absolutely. One prong is attached to a positive wire. The second is to a negative wire and the 3rd (center) is your ground wire.
scooter2013
scooter2013
Answer 9 years ago
Do you know which color? There isn't a red and black wire in this cord. I just want to scrape the wire for a LED project.
caarntedd
caarntedd
Answer 9 years ago
Hot/active/live/positive = brown or red. Neutral/return/negative =blue or black. Ground/earth = green or green and yellow.
Re-design
Re-design
Answer 9 years ago
Hot is not positive!  It is a supply that is alternately positive and negative.
Neutral is not negative.
Continuing to use positive and negative with a/c is just continuing the confusion.
caarntedd
caarntedd
Answer 9 years ago
I'm just using his terminology to say which colour is used for what. For all we know he wants to use the power lead from his P.C. to wire a car stereo to a battery in his garage. Colours aren't posive or negative or hot or anything else until somebody connects them up.
caarntedd
caarntedd
Answer 9 years ago
Ha ha! It took me a minute. Thanks :D
canucksgirl
canucksgirl
Answer 9 years ago
lol.... I figured you'd catch on sooner or later... :D
thegeeke
thegeeke
Answer 9 years ago
If you just want to use the scrap wire, then it doesn't make any difference. Wire used for + is no different than that used for -, although depending on your project, AC cord might be a rather heavy gauge. It shouldn't make a difference, though.
Thermionic
Thermionic
Answer 9 years ago
@Canucksgirl. No, there isn't. This is AC, there is no positive/negative arrangement. There is a hot, return, and ground.
caarntedd
caarntedd
Answer 9 years ago
You're.
thegeeke
thegeeke
Answer 9 years ago
+1
caarntedd
caarntedd
9 years ago
No. One is active/live/hot. The second is neutral/return. The power outlets in your home should supply an alternating (AC) current. Positive and negative usually refers to direct (DC) current. The third is ground/earth. Swapping the active and neutral in this case won't make any difference as long as you don't swap one or the other with the ground. This happens all the time when people make their own extension leads or replace plugs on appliances and accidentally swap active and neutral. Not recommended but should not harm your computer.
