309Views32Replies
Author Options:
Is there a pure knex gun i.e pistol, rifle, crossbow? Answered
I'm looking for a pure, yes pure knex weapon. 100%. I heard that someone made one but I didnt understand the mech so I need pictures. If you show me how to make it and it is good I would be grateful, spread the word of giving it 5* winning a contest and so on. Just post images or instructables. THE RACE IS ON! If you can make one faster than me I will give full credit.
I made one but its very weak, it works as if the tension from pulling a connector back shoots forward. Ty for the knex catapaults but i need guns like pistols instead of those catapaults and such.
An Villain
An Villain
Best Answer 11 years ago
mepains X-bow can use chain and also mepains semi-auto d-construction revolver can be pure if you revolve it yourself. also you can just clip a connector onto a rod (blue clips or tan clips work best) then push the 2 tabs and it will go about 10 feet, i had an idea for making that use a trigger but i am not sure it will work.
charge11595
charge11595
Answer 11 years ago
Thanks for answering!
An Villain
An Villain
11 years ago
here is one, take a silver (3d) connector and put it on a white rod, then add 2 orange connectors clipped on to the white rod (this is the handle/body) pull on the silver connector and it will fire the silver connector a good 5 feet. or you can use mepain's deconstruction revolver and revolve it yourself.
I_am_Canadian
I_am_Canadian
11 years ago
Just make an X-bow with chain instead of string.
knex_mepalm
knex_mepalm
Answer 11 years ago
*blinks as if really confused* could you give a picture. It has to shoot forgot to add that.
I_am_Canadian
I_am_Canadian
Answer 11 years ago
Build mepains Crossbow, and then replace the string with Knex chain.
knex_mepalm
knex_mepalm
Answer 11 years ago
IT HAS TO SHOOT!!!
I_am_Canadian
I_am_Canadian
Answer 11 years ago
I am aware of that. It does.
knex_mepalm
knex_mepalm
Answer 11 years ago
sure, sure it doesn't!!
knex_mepalm
knex_mepalm
Answer 11 years ago
I made it and it does not shoot!
knex_mepalm
knex_mepalm
Answer 11 years ago
I found out that it does shoot, but it works via the tension from the -------- at the end and when you pull the chain back it holds the tension...correct? But still it screws up because the chain breaks
I_am_Canadian
I_am_Canadian
Answer 11 years ago
It shouldent, and anyways, its not even ment to be used like that, if you designed a crossbow around a chain string I am sure it would work.
knex_mepalm
knex_mepalm
Answer 11 years ago
ok i will *attempt* a crossbow which uses a chain, once i get some more chain bits and lots more pieces.
knex_mepalm
knex_mepalm
Answer 11 years ago
Yes, with the chain
knex_mepalm
knex_mepalm
11 years ago
Ok, everyone who has posted here, please note that I am going to change the Topic because we have "discovered" some weapons pure weapons made of knex, but I now will change the topic so it will be "knex gun" so no catapaults because I forgot that they rotate on an axle and use weight to hurl, Etc. IM not being mean. trying to find a gun like pistol or such that doesn't run on bands
TigerNod
TigerNod
11 years ago
My nephew made one in '08, look it up on my instructions.
bounty1012
bounty1012
11 years ago
Ive seen one before, it was a pistol that pulled back the ram when you pulled back the trigger, then it fired a shot. I believe its still here on instructables.
stale56
stale56
Answer 11 years ago
I think that one needs a rubberband because when you pulled the trigger, the ram would pull back, and then when you pulled the trigger farther back, then it would release the ram, and then when you release the trigger, it would go back by the ram... Assuming we are talking about the same gun...
bounty1012
bounty1012
Answer 11 years ago
actually, the gun had no rubberband, but then again, I could be wrong...
DJ Radio
DJ Radio
Answer 11 years ago
You are. That was a true semi auto mech, and it does need a rubberband.
DJ Radio
DJ Radio
11 years ago
I heard there was one around, but I havent seen it yet. Anyways, I would go and try making some hammer mech that would hit the round. Of course, the power would then be related to how strong you are, so it would vary a lot.
knex_mepalm
knex_mepalm
Answer 11 years ago
replied to the wrong guy....could you build it and show me with a good instrutable? running out of bands
DJ Radio
DJ Radio
Answer 11 years ago
I told you that I dont know if it exists, my first statement was rumor based only. Darthvader claimed he made another one, but he forgot the mech before he posted it.
knex_mepalm
knex_mepalm
Answer 11 years ago
Good, just post some picts and i'll give you best answer, could you give me an instructable? I'm running out of #64s
Lowney
Lowney
11 years ago
Isn't that like, impossible? What would be used for the power?
knex_mepalm
knex_mepalm
Answer 11 years ago
Tension, your own strength, etc. My kick is really powerful so if you could make a cannon that would not hurt my foot, that'd be nice
An Villain
An Villain
Answer 11 years ago
mepains crossbow is the only true crossbow, it uses bending arms instead of rubberband tension to fire.
