91Views3Replies
Author Options:
Is there a software to test how much load a structure can hold? Answered
Is there any software where I can identify the material and the structure and then test how much load the structure can hold before it fails? My structure is a spaghetti bridge and I was wondering if such  software exists where I can input the data (material, dimension, shape, etc) and then identify a load unit and start applying it to the structure. Therefore, I would be able to enhance my bridge before execution. Thank you for your help!
knektek
knektek
7 years ago
If you have a reasonably good knowledge of mathematics - mechanics, then you should be able to work it out for yourself, but for the software i'm not too sure.
iceng
iceng
7 years ago
Make a realistic model and stress it to failure.
Not only will it give you insight of the failure mode.
But after conversion from model to real life loading.
You can select a 50% safety factor and build your structure
With reasonable confidence of success.
A
HMN93
HMN93
Answer 7 years ago
First I thought of this but I said I would save some time if I could check my work and calculation using a software. But I think a realistic model is the most accurate representation of the structure.
Thank you!
