331Views8Replies
Author Options:
Is there a way I can cure my procrastination habits? Answered
I have a really strong procrastination habit. I put off doing projects such as posting whatever knex gun I made. It is really messing up my life, and I need some way to help with it. anyone?
aphrael
aphrael
Best Answer 11 years ago
First of all, usually there's a reason you're procrastinating (obvious or not). Maybe finding out the reason for your procrastination helps to stop it? Secondly, I had the same problem and found that for me it helped to: 1. find a nicer place to work (only works if you're a student and can work wherever you want I guess), and if possible move around from place to place. If you don't do actual work at home, you probably have more energy and enjoyment doing projects at home, b/c it doesn't remind you of work. 2. Chop up the day into big chunks (again, if possible in your situation). I find that I work best if I go to the university at 9, work till 2, go home and take a 2 or 3 hour break, then go to the public library to work till 8. After that I go home and do whatever I want. I get a lot more done this way than sitting at the university all day, of which half I'm procrastinating, and then feel like I have to work at night too. 3. Try to set smaller goals that are easier to finish, and do not seem daunting. 4. Just start! :) Honestly, the beginning is always the hardest, while if you just pick up the project you're working on you'll be reminded of how much you enjoy it. I hope this helps at all... good luck!
DJ Radio
DJ Radio
Answer 11 years ago
hmm, good answer. I think the reason I procrastinate is that I dont want to get off of what I am currently doing. I might try to follow this advice. selected as best answer.
The Jamalam
The Jamalam
11 years ago
procrastinators unite! Tomorrow...
fwjs28
fwjs28
Answer 10 years ago
Procrastination holds up our Nation!
DJ Radio
DJ Radio
Answer 11 years ago
Lulz
The Jamalam
The Jamalam
10 years ago
i'll think of a good way to cure it later...
Chaosinfused
Chaosinfused
10 years ago
wow... this really helped ME too, I procrastinate all the time :P
silentassasin21
silentassasin21
11 years ago
what i would do is set a daily scedual and set times for things then after 2 weeks you should be cured
