351Views4Replies
Author Options:
Is there a way I can utilize a Sunsei SE-150 Solar Charger 150mA Trickle Charger to power led lights? Answered
I want to give light to my hydroponic food garden at night and possibly the small pumps.
Torrach
Torrach
12 years ago
Yes you can hook up LED lighting to solar cells.
Myself I have a deep cycle marine battery in the basement closet that is being charged by a bunch of these 1.8w solar cells. I think I'm up to 40 watts max right now. And I'm planning on picking up a couple more today.
I have wiring run between the green house where the solar cells are located, and I have the basement wired with 12V accessory ports all over.
To make LEDs that will run off of twelve volts you have to know a little math, and know the LEDs you have on hand, or can get.
I have an instructable that shows how to make a LED lamp (or just the led panel if you want) at https://www.instructables.com/id/12V_LED_accent_floor_lamp/
frollard
frollard
12 years ago
150mA isn't a lot - what voltage is it? I'm guessing 12v, for a car.
Assuming you get 8 hours of 'peak' sunlight total per day (easy math, adjust for your own conditions)
You get 12v * 0.15a = 1.8 watts.
Assuming 8 hours of sun you get 8h * 1.8w = 14.4 watt-hours. Thats a 15 watt cfl light bulb for about 1 hour at perfect efficiency. One good thing is you wouldn't need much for batteries :S
It's really not a lot of power. This is one of the huge hurdles facing the alternative energy market is it takes a huge investment to get 'a house worth' of electricity out of solar.
ecoego
ecoego
Answer 12 years ago
so I was thinking today about this and I was wondering if a windmill generator would be a better solution.
frollard
frollard
Answer 12 years ago
Wind is great too, still expensive however. Making your own turbine can be a fun experience; check the green group for some cool 'ibles.
