73Views3Replies
Author Options:
Is there a way to change the value of a variable and keep it afterwards? Arduino Answered
Hello everyone,
I don't really know if this is possible, I am using processing, arduino and a force sensitive resistor to control a servo and I want to change the value of a variable and then if I reset the arduino, it will kept the new value. Is there anyway to do this?
This is the part of my code I want to change.
void fsrMovement(){
        int maxforce= 1023;  // THIS IS THE VARIABLE
        if(Serial.available()){  // SERIAL AVAILABLE TO USE WITH PROCESSING
        maxforce = Serial.read();
        force = analogRead(FSR);  // Reads the FSR
        Serial.print("Force sensor reading = ");
        Serial.println(force); // This will print the raw force value
        int pos = map(force, 0, maxforce, 0, 175); // Scales the force reading to degrees for servo control
        Serial.print("servomotor degrees = ");
        Serial.println(pos); // This will print the adjusted servo reading (an angle)
        myservo1.write(pos); // Write the new angle to the servo
        delay(10); // Delay 10 milliseconds before taking another reading
verence
verence
Best Answer 4 years ago
The magic word you are looking for is EEPROM.
It allows persisting a variable's value to survive reset and even a total loss of power.
Check here
iceng
iceng
Answer 4 years ago
+1
rojascan
rojascan
Answer 4 years ago
Thank you! That's exactly what I needed!
