78Views11Replies
Is there a way to set graphical search as default?
I like the new Instructables layout, but the new search feature... not so much. Is there a way to set the graphical search as the default search?
Best Answer 10 years ago
For anyone that finds this question, I just found a way to do as Nick asked: https://www.instructables.com/community/Set-Graphical-Search-as-your-default-search-meth/
Answer 10 years ago
Works even better than the other method, I'll go ahead and give you Best Answer (Sorry Nacho :P) , because it does exactly as I had first intended. Thanks!
10 years ago
. Here's a workaround: bookmark this link.
Answer 10 years ago
Having to pull up that link is more of a hassle than pressing "Graphical Search" IMO. And I think you might have meant this link. The other one just pulls up the normal search page. Thanks anyways.
Answer 10 years ago
. OK. Wasn't meant to be a panacea, just an option. YMMV.
. When I click the link I gave, I get a graphical search, but it's not the same graphical search I get with the Graphical Search link next to the Search button. <shrug>
. BTW, your link doesn't work without some editing.
Answer 10 years ago
Hope my above comment didn't sound rude (I read it over and it did sound very rude), and I could have sworn my link was working. Darned copy and paste. Here, this one should bring up a default graphical search of "a". Didn't there used to be a add-on for firefox that would add an 'ible search bar? Maybe there wasn't, probably just my imagination. *sigh*
Answer 10 years ago
. hmmmm Didn't sound at all rude to me and I can't see how you think it is. <shrug>
. Did you try both links? Did you get a different looking graphical results at each? If you didn't notice, all I did with my link was delete the "a" from the search string (null search string).
. Ppl have created various add-ons over the years, but I don't remember a search bar. My memory's not what it used to be. Ah! That's what search engines are for. :)
Answer 10 years ago
Aha! Thank you! I didn't think of searching Instructables for an addon. I was just searching for addons using Firefox. But, after adding the new "search engine", it uses graphical search, thus solving my problem! Cheers! And I highly recommend that other people use this method also. :)
10 years ago
No. At least not that I know of.
You'll just have to remember to pick "graphical search" and not just "search".
Answer 10 years ago
That's too bad. It's getting kind of annoying having to push it every time. I wish someone would change it back. Thanks anyways.
Answer 10 years ago
Yep. Some of the changes take a long time to get used to.
