183Views3Replies
Author Options:
Is there an easy way to convert a composite or SVHS signal to use a lcd tv as a tv monitor? Answered
basically i want to use an old LCD monitor as a tv... the monitor only has DVI and RGB in the form of a 15 pin HD sub D connector. (like 90% of the computer monitors out there)...  I know that there are expensive "upsync" converters but I want to be cheap...ah hmm frugal... I was wondering if anyone has discovered a cheap way to hack it.
bassbindevil
bassbindevil
11 years ago
Search eBay for LCD monitor tuner.  There's tuner boxes that have VGA passthrough, so you can still use the monitor with a computer.  They have a tuner for cable or broadcast analog TV, and usually RCA and/or SVideo baseband inputs.  They're cheap; $30 shipped from Hong Kong.  You may find similar boxes at local computer dealers or liquidators... I once saw one at a store like Staples.
lemonie
lemonie
11 years ago
What is your source? If it outputs S-Video I'd expect at least one other format.
Can you be super-specific on the LCD - make model?
L
Sandisk1duo
Sandisk1duo
11 years ago
If you get a DVD recorder, you can put in Composite, and the DVD recorder will output an RGB signal
then get an RGB to VGA adapter
