973Views21Replies
Author Options:
Is there any sensor that can detect human skin? Answered
I am working on a project that  involves detection of skin. The sensor should be in such a way that it should differentiate human skin from other objects like wood,plastic,metal.
Tags:sensor
Yonatan24
Yonatan24
4 years ago
What project? You need to be more specific.
Lorddrake
Lorddrake
4 years ago
yes. that is how a touch lamp works.
For even higher end sensors, check out a product called sawstop. It is a table saw that will stop in 1/1000th of a second to prevent cutting off a finger. It mangles the saw but saves your digit.
verence
verence
Answer 4 years ago
Well, no. Both of your examples work with capacitive coupling. You can trigger them by touching the sensor / blade with a piece of metal you hold in your hand.
krishnaramya
krishnaramya
Answer 4 years ago
can you give me any information about capacitive coupling .or any links which could help me understand,
krishnaramya
krishnaramya
Answer 4 years ago
can you give me details about about capacitive coupling
iceng
iceng
Answer 4 years ago
+1
Lorddrake
Lorddrake
Answer 4 years ago
can you be more specific about what you are trying to accomplish in order to get a better answer to your question.
krishnaramya
krishnaramya
Answer 4 years ago
while cutting operation there are serious accidents so inorder to avoid this i need a sensor whichich detects human skin
verence
verence
Answer 4 years ago
Something like this?
krishnaramya
krishnaramya
Answer 4 years ago
yaa like that only but any other sensor which can sense skin
rickharris
rickharris
Answer 4 years ago
Cutting what exactly?
krishnaramya
krishnaramya
Answer 4 years ago
cutting wood or metal other than skin
krishnaramya
krishnaramya
Answer 4 years ago
yaa i saw that. dont know the operation.
Vyger
Vyger
4 years ago
Just take a bite, if it screams or hits its probably a person.
Rahul - S
Rahul - S
4 years ago
I think mobile touchscreen may help you.
You can check that nothing else is sensed by cellphone touchpad except our fingers and other body parts.
iceng
iceng
Answer 4 years ago
Conductive foam tip metal pencils work very well when your old skin fingers are too dehydrated to activate a touchscreen.
rickharris
rickharris
4 years ago
I think the simplest way would be to look for body heat with a thermal sensor. Most non human things are hotter or colder then humans - HOWEVER you skin can be cold depending on the place and weather. Indoors you are probably OK. but perhaps combining 2 sensors will be the answer say heat and colour.
iceng
iceng
Answer 4 years ago
That is why reflecting infrared light ( LED ) off blood cell pulsations works giving skin a unique biometric compared to inanimate materials which could be colored to resemble skin.
Skin is transparent to IR. Blood however reflects IR.
rickharris
rickharris
Answer 4 years ago
What about other animals?
iceng
iceng
Answer 4 years ago
Body temperature and hair blocks IR
rickharris
rickharris
Answer 4 years ago
Didn't know that.
iceng
iceng
4 years ago
A combination of two or three sensors should do be able to differentiate.
OBJECT------------I_R-------------CONDUCTIVE-------------THERMAL
PLASTIC--------yes_&_no---------USUALLY_NO-----------------NO
METAL--------------NO---------------YES_Strong-------------------NO
SKIN----------------YES--------------YES_weak-------------------YES
IR
light passes through skin and reflects off of blood, so reflected
INFRA-RED light can detect heart pulse rate. A pulse rate detector
may be the only sensor needed.
But there are skin areas that have no evident pulsing blood !
