2792Views13Replies
Author Options:
Is there any way to bond two small pieces of Aluminum together? Answered
I have been told Epoxy, but i'm making a ring and I want to attach a small cross to it. It needs to be durable too.?
steveastrouk
steveastrouk
Answer 8 years ago
welding is not soldering.....
The MadScientist
The MadScientist
Answer 8 years ago
I'm a little unsure about what to call it some people say it's welding others say it's soldering because of the low temperature filler rod.
steveastrouk
steveastrouk
Answer 8 years ago
Welding - joint with SAME filler metal as parts. Always takes place at the melting point of the parts.
Soldering - process where relatively lowtemperature metals react with metals of the joint by dissolving into solid solution to form a joint.
Brazing, essentially the same as soldering, but a higher temperature process using different metals, gives a stronger joint.
The MadScientist
The MadScientist
Answer 8 years ago
The filler rod is not aluminium. I think it's an aluminium/ tin alloy melting temp around 300 degrees C.
steveastrouk
steveastrouk
Answer 8 years ago
...so its not welding, its soldering.
mpilchfamily
mpilchfamily
8 years ago
Why bond a small cross to the ring when you can easily carve the cross from access aluminum at to top side of the ring.
iceng
iceng
8 years ago
I have a hereditary hand tremor that is sonic, some say ultra-sonic.
The benefit to my condition is, I can solder aluminum by vibratory
exclusion of the near instant oxide layer prior to the hot alloy forming
metal bond while the hand held solder iron keeps the metal clean :-)
A
vince 09
vince 09
8 years ago
I used JB to put the pocket clip back on my pocket knife when the screws broke and it works great still using it today
mrmerino
mrmerino
8 years ago
Try JB Weld. I've heard good things.
Wylder Barrows
Wylder Barrows
Answer 8 years ago
If I use JB weld will it be able to withstand stress such as drops, hits, and other stress?
mrmerino
mrmerino
Answer 8 years ago
Frollard, can you get this? I'm only vaguely familiar with the properties of JB weld.
