99Views4Replies
Is there away to fill in these huge gaps in this wood frame?
I have this mirror that I like but it came with these huge overly sized lamps attached to it which I didn't particularly like and removed, which has left it with two large gaps in the frame.
Is there a way to fill in these holes where I could possibly just paint over it so everything looks even or some sort of creative way to fill them in?
here is what it looks like.
front
http://i11.photobucket.com/albums/a152/Meghan_l_d/DIY/DSCN1239.jpg?t=1275868085
close up of gap
http://i11.photobucket.com/albums/a152/Meghan_l_d/DIY/DSCN1241.jpg?t=1275868112
back
http://i11.photobucket.com/albums/a152/Meghan_l_d/DIY/DSCN1242.jpg?t=1275868112
10 years ago
You COULD use brass (or aluminum, depending on which you like better) ornate plates to use as covers.
10 years ago
I think you should put in some wood blocks that protrude and pegged with wood square pegs. I think you have something that is reminiscent of Arts and Crafts or Mission style. I don't know if this will be hallway mirror or dresser so adding the blocks that look like the end of a timber frame beam would give you a place to hang stuff or put a bud vase on top. I hope you are doing some kind of wood finish and not just paint which would cover up the natural wood. Good luck.
Reply 10 years ago
It will be in my bedroom above my dresser. I've used it for the past year to apply my make-up in the morning and the hooks to hang up jewelry. I've just gotten sick of looking at those gaps. That's a pretty good idea about the the blocks for additional hooks. Oh, no definitely a wood finish. Most of my furniture is dark brown, almost black, wood- so I was looking at sanding it and staining it a darker tone.
Reply 10 years ago
Chisel-out to nice surfaces, fill-in with shaped, matching wood blocks and glue.
Take off the surface-finish, stain/distress as necessary, re-laquer / varnish.
Or admit that you'll see the join and think about hiding it with some inlay(stain/distress as necessary, re-laquer / varnish.)
L
