65Views5Replies
Author Options:
Is there something wrong with my computer? Answered
I have an Asus (Intel) Computer, and what happened is, that my battery always say 0%, charging. I trying using a brand new charger, but it still doesn't work! And I used a different outlet too! That still doesn't work. Is there any problems with my computer or charger?
Yonatan24
Yonatan24
5 years ago
Your computer and charger are fine, Your battery life is dead. Buy a new battery
Yonatan24
Yonatan24
Answer 5 years ago
Or make one, If you know how to
-max-
-max-
5 years ago
If it is old, then it is likely that the battery is either damaged or just too old and needs to be replaced. Lithium batteries degrade when:
They get too hot
They get too cold
They get over-charged (or stay charged for too long)
They get over-discharged (or stay discharged for too long)
They get charged too fast (too many C's or amps)
They get discharged too fast (too many C's or amps)
They get old.
-max-
-max-
Answer 5 years ago
If you can rebuild or replace the battery pack, that is what I recommend. Be careful if you choose to try to build a new battery pack though, protection PCBs are a must with dealing with lithium ions, and cheap lithium ions that flood Amazon and eBay are no good, not even worth there minamal costs.
Downunder35m
Downunder35m
5 years ago
I could tell you if I use my multimeter on it...
But seems you ruled everything external out, which means either the battery or the electronics charging it are toast.
If you are lucky it is only the connector on your laptop that has faulty soldering connections to the mainboard - usually a light comes on when you connect the charger, no light would mean no power going in.
