270Views1Replies
Author Options:
Is this a good paintball gun? Answered
I am thinking of getting the syndicate misfit paintball gun. Does anyone have one or experience with one. here are the specs: The Misfit is the ONLY marker in its class to operate at low pressure using CO2. Its precision performance and engineering detail make this marker the most powerful at its level on the market today. +2 piece 14" barrel +multi mode electronic grip frame +adjustable rate of fire up to 16 balls per second (BPS) +3 firing modes (semi auto, 3 round burst & full auto) +LED light Display +enhanced volumizer +3/4" gauge +vertical Feed +leak proof valve (US patent 3.553.983) +adjustable double trigger +push button safety +deluxe field strip pin +spring loaded ball detent +vertical adapter +external battery charging port +top & rear cocking +Gloss anodized finish (also available in green to black fade finish) +milled body +standard bottom line adapter +velocity adjuster with lock +adjustable in line regulator +all metal gun no plastic exterior parts!
Harmonator
9 years ago
Ya thats a great gun...i would deffinetly buy it.
