3090Views9Replies
Author Options:
Is this the right way to get 15 Volts out of PC Power supply?? Answered
So, Can i get 15 V out of Power supply if i wire +12 V to ground and -3V to ground and then pull a wire from the +12 to + on the device and -3 to - on the device.
Ex.
+12--|
Gr.----------------------------- +
Gr.----------------------------- -
-3----|
Gr.=ground
-=wire
|=means connecting something
steveastrouk
steveastrouk
Best Answer 10 years ago
NO ! Put your load between +12 and -3 !! DON'T CONNECT THEM DIRECTLY
Steve
delokaver
delokaver
7 years ago
here you go ...
http://danyk.cz/at_atx_en.html
Quercus austrina
Quercus austrina
10 years ago
Follow steveastrouk's directions!!! Leave the GND connection out of the hookups, as the -3.3V becomes the new GND.
Voltage is the potential between 2 connections. Do you remember number lines from math? The distance between 2 numbers on a number line is the absolute value of each number added together (if they are on opposite sides of 0) or the absolute value of each number subtracted from each other (if they are on the same side of 0). So, since -3.3 and 12 are on oposite sides of 0 (GND), the total is |-3.3|+12=3.3+12=15. Since you are going between -3.3 and 12, you leave out 0 (GND) from your connections. See below:
-3.3 --0-----------12
If you were to connect the GND, you would blow the PSU.
Qa
aksuduud
aksuduud
Answer 10 years ago
OK, By the way does the .3 Volt difference blow up my stuff? im too lazy to figure out anything to convert it.
steveastrouk
steveastrouk
Answer 10 years ago
I doubt if you will have a problem with the 0.3V
Quercus austrina
Quercus austrina
Answer 10 years ago
I concur, it most likely won't have any effect on the circuit. Also, the amperage (current) will be limited to the weakest side, meaning that the lowest amount is what you could possibly use. If you were to use one side (+12 volts, for example) at 20 A(mps), and the other (-3.3 volts) at 6 A, you would only be able to pull 6 A maximum from your repurposed PSU. This is just a theoretical situation, your numbers may vary.
Ideally, you would want the 2 sides to be matched in current capabilities, but this is an imperfect world and it is hard for hobbyiests to match things from existing, repurposed items.
Qa
Quercus austrina
Quercus austrina
Answer 10 years ago
Oops, 3.3+12=15.3, not 15. I was doing a quick reply.
Qa
steveastrouk
steveastrouk
10 years ago
No, you may be able to take up to the limit of the -3V rail by connecting from 12V to -3.3V
Steve
aksuduud
aksuduud
Answer 10 years ago
Uhh, you mean connecting +12V to -3.3 right? and then what? im pretty new to this stuff.
BTW anyone who has any idea how to get 15V out of PSU please post.
