216Views6Replies
Author Options:
I've made a hot wire foam cutter, but it is always burnig transformers. what should I do to avoid that? Answered
mpilchfamily
mpilchfamily
Best Answer 9 years ago
can you give a schematic for your build? Are you running the wire straight off the transformer? What if any circuits do you have between the transformer and the wire that help limit the amount of current to the wire?
tgferreira184
tgferreira184
Answer 9 years ago
i follow this instructable:
https://www.instructables.com/id/How-to-make-a-simple-foam-cutter-from-scrap/
but I've used nichrome wire from a heater
mpilchfamily
mpilchfamily
Answer 9 years ago
Your problem is the wire your using. The wire draws way more current then what your transformers can support. Foll ow the intructable and use a guitar string.
tgferreira184
tgferreira184
Answer 9 years ago
how can I build it using nichrome wire?
lemonie
lemonie
9 years ago
I don't see any transistors in that Instructable.
L
steveastrouk
steveastrouk
9 years ago
You should design it with a view to how much power the wire will draw from the transformer.
That starts with knowing the resistance of your "hot wire".
Steve
