93Views10Replies
Author Options:
Knex Gun Force Standard Answered
The problem is that almost no one has enough room inside to shoot a knex gun unless it's a total peice of ....you get the point. But, by going outside there are many other vaiables that effect how far a gun can shoot (eg. Wind direction/ speed, trees and other obstruction, etc.) Also power as in "can shoot through can" or "through 3 sheets of hard cardboard" can also be misconstrude in the way that range from the can is a main factor, point blank range is not always the most powerful range, often 1-3 inches away has exponentially higher power. What needs to happen is a tool be built (out of K'nex, what else?) that is not only easy to use but impossible to mess up, it should be able to give 100% accurate reading for all types of guns from the weakest to the most powerful. Also in terms of different types of ammo, rod size shouldn't matter( thats what she said) the only thing that should matter in terms of ammo is whether it is deer slug, rod, sligshot/ catapult rod(a rod with something the can grab the elastic), or other and specify what that is.
Range is all to often streched beyond reality by saying it can shoot 200 yards, when really it might be able to shoot 50 yards tops when pointed strait but 200 yards if it is pointed strait at the sky.
We need to bulid a target that you shoot from maybe 5 feet away and something mesures force, be it cardboard, or cans, or plywood, maybe even something that leaves a dent in it and you can mesure the depth of the dent to tell you how much force (eg. 1/2"=1, 1"=2, 1 1/2"=3, etc.)
Also one last idea if you would prefer to stick to range outside, is that you divide the range in feet, by the number of cardboard sheets(or other medium)the gun can shoot trough at point blank range (say it shoots 63 feet, and through 4 sheets of thick, corrugated cardboard the equation would be F= 63/4= 15.75, so your force rating would be 15.75)
These are only some ideas to get all of you thinking about a standard in K'nex gun power.
-TheXenk
Oompa-Loompa
Oompa-Loompa
11 years ago
rod size shouldn't matter( thats what she said) LOL
knexfan9182
knexfan9182
Reply 11 years ago
well the rod size gives it more momentum and typically less speed
flames10391
flames10391
Reply 11 years ago
THATS WHAT SHE SAID!
TheXenk
TheXenk
Reply 11 years ago
Yes but what I am trying to say is that if you have a gun that can shoot through 7 sheets of cardboard and has a range of 120 feet the rating would still be 17.14 it doesn't matter whether you shoot red rods or pink elephants( well shooting pink elephants out of a knex gun would be a bad idea!) your result is the same, rod size is just a variable withno effect on actuall testing. It may may a tiny difference i Dont know, but i will try to find out the different amounts of force different sized rods have(THAT IS WHAT SHE SAID!!!)
Oompa-Loompa
Oompa-Loompa
Reply 11 years ago
no, I was laughing at what he said, nice job ruining the ,joke. LoL I'm just messing with ya.
knexfan9182
knexfan9182
Reply 11 years ago
yeah i dont really care much im about to go to bed
TheXenk
TheXenk
Reply 11 years ago
haha nice
TheXenk
TheXenk
11 years ago
By The way I can't figure out how to edit this topic so... Credit to Sypran for this topic idea!!
