175Views11Replies
Author Options:
LED Voltage Help Answered
I recently purchased 10 led's from superbrightleds.com but I cant seem to figure out their voltage. I am not good with electrical terms (I am a noob with electronics) so the led's detail page just confuses me. If anyone could figur out the voltage of them by going to this page here it would be a lot of help. Thanks!
steveastrouk
Best Answer 7 years ago
3.8 V @ 30 milliamps
Steve
DBModssteveastrouk
Answer 7 years ago
thanks a lot! i tried to figure it out for 2 hours one day with no luck!
The Skinnerz
7 years ago
The maximum forward voltage, which is the maximum voltage accross the LED when it it working, is 3.8V, but it is best to run it at around 3.3V (2X 1.5V batteries will be fine)
The Skinnerzsteveastrouk
Answer 7 years ago
Why not? (I'm not questioning your knowledge, I'm just interested as to why.)
steveastroukThe Skinnerz
Answer 7 years ago
Look at the graph of current against voltage. The forward volt drop is the volt drop at the operating current - so by definition, at any voltage BELOW that, you aren't getting the operating current to flow.
Steve
DBModssteveastrouk
Answer 7 years ago
wait so what voltage should i run it off of 3, 3.3, or 3.8?
steveastroukDBMods
Answer 7 years ago
You HAVE to use a resistor, which depends on the supply voltage you have, to limit the current. Tell us what voltage you want to use, and I can size the resistor for you.
Steve
The SkinnerzDBMods
Answer 7 years ago
Steve knows more about electronics than me, so I'd follow his advice and use 3.8V, but I'd be interested to see how much difference there is between 3V and 3.8V
seandogue
7 years ago
I'm sorry Steve, you're saying that he should operate these LEDS at the maximum specs? Best answer or not, that not right.
steveastroukseandogue
Answer 7 years ago
I don't think its a particularly bad design point for the leds chosen, yes, if they are in full outdoor ambients I'd have chosen a more conservative point, but here ?
