112Views4Replies
LED wiring standards?
Making a wooden rangehood for my wife for our annivesary, and I want to use LEDs for the light source. I wan to use 3 banks of 30 lights in each 4X8" oval space, and from what I have read it would seem to better to wire each set in parallel. My question is, do I need to put a resistor on each LED to adjust the voltage to the proper amount, or (since it is wired parallel) will one work for all?
10 years ago
one current regulation device per led, whether a resistor or other from of current limiter.
Answer 10 years ago
* if in parallel
10 years ago
I'd suggest buying a few LED light strings from someplace like dealextreme.com. Then all you'd have to do is feed each one with 12V and you're done!
One word of caution, though: The light spectrum from a set of LEDs is very different from incandescents; so much so that the food you guys prepare may look different than when it's served. A mixture of "cool white" and "warm white" LEDs may help.
10 years ago
Its better to put them in serial strings with one resistor per string.
