90Views5Replies
Author Options:
LEDs are putting static on my stereo? Answered
i wired a outlet so I could plug in a strip of LED lights that are able to run in different modes (flash, fade, different colors, etc) When I turn the LED lights on, the stereo, that is plugged into a different circut, has static that goes with the tempo of the lights. When I turn the lights off there is no static. What gives?
Here is what I got.
http://www.amazon.com/dp/B0040FJ27S/ref=pe_175190_21431760_cs_sce_dp_1
I used them in another part of the basement and they work good with no problem. i also checked the outlets with the 3 light tester and it says it is wired correctly.
steveastrouk
steveastrouk
9 years ago
The LEDs are being switched by high frequency signals, which are interfering with your stereo.
You need to put a bit of filtering on the cables to the LEDs
thegeeke
thegeeke
Answer 9 years ago
+1... Also, if they have a ground, wouldn't putting a ground lift in help as well?
steveastrouk
steveastrouk
Answer 9 years ago
Yes, maybe.
Also try a mains filter, but I doubt this is mains conducted.
Steve
thegeeke
thegeeke
Answer 9 years ago
Right. One thing I run into a lot is people plug their laptop with a ground into the same circuit as a soundboard. (Now first of all the soundboard and amps should both be on their own circuit.) I end up having to re-ground the laptop to something else or another circuit so that the grounds aren't interfering with each other. :(
iceng
iceng
9 years ago
The question should be,  is it radiated noise, conducted noise or both ??
