95Views6Replies
Author Options:
Large Speaker Driver needed.? Answered
I have a large 8ohm speaker with a "12W500" rating, and another sticker saying 3/38/5 (QC check?)
~18cm Magnet and 30cm Cone.
I want a signal generator for  chladni plate (vibrating plate)
I know how to make a signal generator from a 555, but i dont know how to drive the speaker magnet.
Do I put the output to a "power transistor"? I have only used them for signal amplification before not power supply..
Will it run on 12V, 3V 24V? What kind of amps may it draw 200mA 500mA? 1A? 4A? I don't even know ballpark figures!
Any tips, Circuits or transistor reccomendations will be VERY appreciated... I am fairly proficient at electronics, but this eludes me completely as it is taken for granted in most instances, or they use a 300€ amplifier....
I already build a signal generator.
Cheers
steveastrouk
steveastrouk
7 years ago
Just buy a Velleman 200W monoblock amplfiier kit. Job done, and for about 30 dollars AFAIR.
Steve
steveastrouk
steveastrouk
Answer 7 years ago
http://www.vellemanusa.com/products/view/?id=522104
oliverkellow
oliverkellow
Answer 7 years ago
thankyou i will consider it, but personally i'm more interested in using what I have and learning how it goes.
It seems to me a MOSFET, or something would be easier because i am only transmitting a rough square wave signal and i already have a low power 555 generator.
steveastrouk
steveastrouk
Answer 7 years ago
You could use a MOSFET in an amp, but it will need to be quite a big one, and running in class B or it will burn up. A lot more bits than a single transistor.
Of course, even a TDA2030 or similar might be enough, if you're only driving a plate.
