2619Views9Replies
Laser diode driver?
Dear all..
I would like to use this circuit (please see photo) for driver a laser diode to engraving wood
-Item Name:ML101U29-25 (Mitsubishi)
Power output: CW 300mW
Pulse Power: 400mW
Working Current: <340mA
Working Voltage:2.2-3.0V
I know about this formula I = V/R But in this circuit I am not sure for calculate current .So please could you help me to know how many (mil.amp) I must setting for 9 volts power with maximum output 300mW (with safe laser diode ).
-Or you show me other best circuit
Many thank you.
Best Answer 5 years ago
1. it is a dirt cheap driver.
2. I hope you are not talking about a 9V battery here.
3. You will need a proper multimeter to set the circuit right - there is no other way.
Answer 5 years ago
Hi Downunder35n
Thank you for your reply . Please Could you explain more why
you said :* not talking about a 9V battery here*
for me easy understand Thank you so much
Answer 5 years ago
You laser uses quite a bit of power and a 9V block battery is about the weakest energy source you can find for that voltage.
AA batteries are quite small, AAA even smaller - in your 9V battery are 6 1.5V batteries that are smaller than a AAA.
Since you need less voltage anyway either use 3 D-cells or a wall adapter - those for mobile phones, providing 5V and 2A would work fine too.
Answer 5 years ago
I made a diode driver awhile back and I found that using 4 D cells made it the brightest but still didn't pop a balloon (I was using a RW dvd laser!) just something I found
Answer 5 years ago
Hi bravoechonovember1
With my little experienced You need 2 things for do pop a balloon :
- power laser from 50mw or more
- focus lens must be right in place more power more easy adjust the lens .
Thank you
5 years ago
Dear steveastrouk and iceng
Many thank you for your time help me.
5 years ago
The circuit lets you adjust the current from a high of 240ma to a low of 12ma.
The only consideration for the battery is if it is capable of sourcing the desired current and exceeds the laser forward voltage plus three volts.
I am curious if the laser diode will lase over that range that simple constant current circuit will do. Also that pot may be too small.
Answer 5 years ago
sure won't carry 240ma. There are ways round the issue though
5 years ago
I=1.22/R ?
