369Views8Replies
Author Options:
Lethal Ozone From Flyback Transformer? Answered
I am running a flyback transformer with a 2n3055 transistor which works perfectly giving me 2cm arcs but i get a weird smell ever time i run it for more than 10 sec i think its ozone is it lethal im using a 12v 2A power supply
-max-
-max-
Best Answer 4 years ago
Nahhh you're fine :)
It can be lethal, it's a bit like chlorine in terms of chemical properties I think. Use a bit of ventalation and you should be perfectly fine!
russkeller
russkeller
9 months ago
No need to be concerned on this one. Ozone is merely 3 molecules of oxygen held together by the extra electron pushed in by the high voltage. It is not lethal and you will NOT find ozone as listed as a cause of death anywhere. That is all hype and misinformation. Ozone can be very pleasant is small concentrations but, if you read the MSDS (materials safety data sheet) on it, can cause irritation at high concentrations. Ozone is more effective than chlorine at killing pathogens and disabling viruses by dissolving the lipid layer over the DNA snippit, it is used in water purification, swimming pools (the expensive ones) and is disinfection of all sorts. It's non carcinogenic and is made with electricity and oxygen.
Yonatan24
Yonatan24
4 years ago
What's that smell? Does it smell a bit cool and refreshing?
TheGreatResistor
TheGreatResistor
Answer 4 years ago
Exactly like it was rushing in my nose and felt like a cool smell
steveastrouk
steveastrouk
4 years ago
Ozone in high concentrations can be lethal. Short exposures to the tiny amounts in your arc are just unpleasant.
Sunlight creates ozone at ground level, especially near the sea.
Yonatan24
Yonatan24
Answer 4 years ago
I'm not the one that asked the question, but am wondering:
That "cool, refreshing, yet kind of weird" smell that comes from ionizers (or his (Jacob's Ladder?)) is the ozone, or the negative ions?
I've heard that the ozone that comes out is dangerous in high quantities can slowly dissolve plastic too
Jack A Lopez
Jack A Lopez
Answer 4 years ago
I love the smell of LOFFT (Lethal Ozone From Flyback Transformer). That smell. That ozone smell. It smells like high voltage victory.
;-P
Kiteman
Kiteman
4 years ago
Does it smell like a photocopier?
That's ozone, but you'll be fine if you keep the space ventilated, preferably with the air flowing from you to the device to the the outside.
