91Views3Replies
Lights inside glass block
I have painted several glass blocks for a craft show. When I put the lights inside and turn the block back over, all the lights fall right to the bottom of the block and the top of the block is not lit. I see yours are lit and most of the ones I see are lit up top. I tried glue dots which only stuck to my nails instead of the glass block. Any suggestions?
4 years ago
A glue gun will stick well to glass BUt not to anything that gets hot so use LED lights.
Answer 4 years ago
UV curing, clear resin comes to mind, like the stuff used for making crystal figurines, lamps and such...
4 years ago
If you have question to an Instructable it is only logic to ask there.
Seems like you are talking to an invisible friend here ;)
