Logitech X 620 sub pinout?
Found a powered subwoofer ( Dumpster!!!) of a 6.1 computer sound system. Not the 6 smaller speakers. The front right speaker would have had the inputs and controls in it . A cable with a VGA connector had to be plugged into the amp in the back. No pinout info was found
I have a similar 2.1 system (Logitech Z3), which is all I need for casual use (My real system is unusable due to neighborhood pressure...)
The amp contains 2 TDA 7377 chips,and many more components than prescribed by the data sheet (some of it is the power supply)-
( Does more complicated mean better here?).
2 Options:
1) rip the TDA chips out and use one to make a 2.1 or a stereo amp with components according to the datasheet. The other one a stereo or quad for a different project.
2) find out the pinout and use the amp 'as is' (which would mean putting both all R and all L channels together (parallel?) to make a 2.1. A lot less work.
(Since I am not going to use the 6.1 configuration, will the sophistication of the design still deliver?)?
If anyone knows the pinout I would of course first try working with the existing circuit...
2 years ago
Hello, Did you get this subwoofer to work as a standalone spreker? If so could you please share how. I have a logitech x-620 subwoofer no other speakers. Thank you for your time.
8 years ago
Here's What I've Found
http://blog.jseaber.com/2010/02/27/logitech-z-2300-control-pod-disassembly/
i need the same diagram :) if i found something will let you know and share here, if you find something else please share with us :)
8 years ago
Quick Google search.
http://pinouts.ru/Home/logitech_x530_front_pinout.shtml
Hope this helps, It looks pretty simple
