80Views3Replies
Looking for a particular light bulb socket?
I am looking for a standard light bulb socket that can be soldered onto a circuit board. It would need two pins that could fit into a printed circuit board and then soldered. Do they even make such a thing?
6 years ago
You could probably modify something like this:
http://www.ebay.com/itm/Leviton-Phenolic-Lampholde...
Use the wire terminal screws for mounting and solder the screw head to
the pcb trace
6 years ago
Make a tinnerman nut and screw a bulb into a PC Board.
I did a large Keno flash-board this way.
https://www.google.com/search?q=tinnerman+nuts&sou...
6 years ago
Standard light bulb socket..you mean like screwbase ones?
Uhm i didn't think so. i do know that there are those with tabs sticking out at the bottom (for wires and screws when mounting). seen those on smaller sockets like E10. you could bend those a little to fit flat on a board and treat it like a large Surface mounted device by soldering them to large pads...
