96Views4Replies
Author Options:
Looking for a radio transmitter and cheap receiver? Answered
So, to simplify things, I want to power a heap of LEDs that run off exactly 5v of power when I press a button (and stop when I release) from 300+ meters.
I'm looking for a radio transmitter that has around 300+ (bigger the better) range that can communicate with a large heap of receivers. I'd prefer if the receivers are fairly cheap because I'll be using them in large quantities, but I'm happy to spend under $100 with the transmitter. On use, I want the receivers to output 5v of power into the LEDs. The transmitter doesn't need to transmit anything special, just a signal at all will suffice, with an easy on/off switch on it.
I'd be happy to lower my range to around 200 if necessary, but its not really ideal. The receivers need to be fairly small. Thanks a lot for any help/suggestions :). My electronics knowledge in this area is fairly limited.
Thank you again
FarmerKJS
FarmerKJS
5 years ago
How many recivers do you need?
HarryA3
HarryA3
Answer 5 years ago
Room for large improvement. I'd say 100 max
