22660Views31Replies
Low voltage, high amperage transformer?
Hi! I would like to make, buy, or find, a low voltage high amperage transformer to power an electrolosis cell. I like playing with the hydrogen-oxygen gas produced. From what I have read, I only need about 1.8 volts for electrolosis, so I'd like a circuit or transformer that could take the power from preferable a 9 volt battery and convert it to 1.8v at as high an amperage as I can get. Thanks : )
5 years ago
transformers only work with alternating current. You can easily wire your own transformer. I made a power supply that converts 120 volts ac to 12 volts dc. It puts out over 50 amps, i know this because i blew my 50 amp fuses a few times. If you take a microwave transformer and cut out the secondary coil but leave the primary alone and be careful not to damage it. You can use 10 awg or larger i used 6 awg wire. If you want to get around two volts I would use 4 awg or larger and just rap the coil one or two times. The plug it into the wall and read with a meter the secondary side. It should only be a few volts but very high amps. Then just run the secondary side through a bridge rectifier then a few capacitor and an inductor. Sounds complicated but its very simple. Make sure your capacitors a large enough to handle the peak to peak voltage of what your secondary is. What ever reading you get i believe you multiply that by 2.14 and that is your peak to peak voltage.
Reply 1 year ago
how much would u charge to make that. i need one too
Reply 6 months ago
You're better off going on ebay and searching "12v 100 amp power supply" or something like that. There are a lot of relatively low priced, high power, 12 volt power supplies used for bitcoin mining equipment. These are basically rack-mount server computer power supplies with more user-friendly power connections on the back. If you build the modified microwave oven transformer, you will need to rectify the output because using AC power for electrolysis won't work. The alternating current will basically keep switching the anode and cathode, resulting in no reaction/gas produced, and will just heat the water. Therefore using a production DC power supply is a better idea. You can also use any computer power supply -- right now I'm in the process of adapting a 1250 watt PC power supply for this exact purpose. I cut the ends off the PCI express power connectors, and crimped on ring terminals to hook them up to high current bus bars. But if you're buying a new power supply, save yourself the trouble and get one of the high current 12v ones from ebay/Amazon/Aliexpress. You only need 1.8 volts or whatever in theory, but having higher voltage helps electrolysis work better since more voltage means more power to push the gas bubbles off your electrodes, from what I understand.
If you want to see an example of the microwave oven transformer, check out this youtube video:
Making things melt/making a big arc/spark doesn't require DC current, so the transformer output can be used directly in that example.
3 years ago
any one There??
3 years ago
hey guys!.
5 years ago
I forgot to mention I made this power supply for my HHO torch and it works great. I have posted a video of the torch and the power supply on my facebook page. If you can access it from this page then check it out if not and you are interested then email me at lewdogfrog@gmail.com and i will get you the video and the power supply info. This is very easy to do and good luck.
6 years ago
if possible how??
6 years ago
is it possible to power an electric motor which is 75 volts and 500 amps using this kind of transformer from a 12 volts car battery???
9 years ago
Don't use batteries it will suck them dry very quickly. And besides transformers only function with AC power, which you would need an inverter to run from a battery.
If you had to use a battery you would want a car battery, you could probably find one easily, and they can put out HIGH amperages for short periods of time. If the 12V is just overkill you can spread it out over several cells like Christmas lights.
Answer 9 years ago
just the other day, i rewound a Microwave transformer. its not very hard to do, and it does product the desired current and voltage. UNFORTUNATELY AC current does not split the H2 and the O2. DC is required.
Answer 8 years ago
You need a bridge rectifier to convert the AC voltage to DC Voltage . on the secondary windings of the transformer in order to produce the DC required for electrolysis. A bridge rectifier is simply a set of 4 diode connected in a square with the poles facing "+" to "+" on one side and "-" to "-" on the other then joined together on the other ends. Like so:
T1
L1 ____ + +____L2
T2
L1 and L2 are the line voltage AC coming in
T1 and T2 are the DC output.
BTW high amps can kill you.
12 years ago
you could re wind a microwave oven transformer to put out low voltage at very high current. at 1.8v one could give you 400 - 500 amps.
Answer 12 years ago
That sounds great! How would a go about rewinding one, after I find it?? What gauge wire would I have to use?? Would I be able to get that much from a 9v? Would the battery die almost instantly?? Sorry about all the questions, thanks a lot! : )
Answer 12 years ago
You can get the transformer from a dead microwave (you should be able to get one from craigslist for free) the higher wattage the microwave is the more power you will get out of the transformer.
Microwave ovens have a large capacitor you have to discharge before touching any of the wiring; you don’t want to get zapped by it.
Once you get the transformer out you will want to cut off the secondary winding (the large coil of thin wire) but don’t damage the primary winding (the coil of heavy wire) you will wind some heavy wire where the secondary was. The voltage is typically .8 to 1.2 volts per turn on the secondary (depending on the transformer) you will want 3 to 6 volts for your hydrogen generator.
8 or 10 gauge wire should be heavy enough for what you need. That should give you 30 to 50 amps (more than enough for a large hydrogen generator) but heavier wire could be used for more current.
The output will be ac which will be fine unless you want to collect the hydrogen and oxygen separately.
Be sure to put a fuse on the primary and secondary of the transformer.
The transformer should be placed in an enclosure to prevent anyone from coming into contact with the dangerous voltage on the primary.
Google "how to rewind a microwave transformer" and you will find a lot of info.
This instructable gives some onfo on rewinding a microwave transformer.
Answer 11 years ago
sorry to add up the comment in btwn but i have a question ... what if i wanted to have a same voltage like around 3 to 10 volt but way more higher current .. like around 20,000 to 40,000 amps ... is it possible to get something like this from microwave transformer ?? or can i just add few more transformers in series and obtain more current? plz let me know as i m working in a project that requires amps in k .. so any thing starts with 20k amps works ... thank you and i m in time line to finish this project up .. so help me out over here and i'll really appreciate it ;) thanks
Answer 12 years ago
Thanks! : ) There's a lot of helpful stuff there.. So, what I'm thinking, is that I'm going to take a 9v battery, through a 555 timer for oscillation, and put it through this modified MOT and that will give me the power I'm looking for?? Or you're thinking I'm running the transformer from 120v AC and I have it all wrong?? : ) Thanks, this is a lot of help. Sorry about all the questions..
Answer 12 years ago
The mot runs off of 120v ac (or 220 depending on where you are). A 9v battery won't provide more than a few watts of power. If you needed the hydrogen generator to run off of a battery and produce a usable amount of gas you would need a car battery.
Answer 12 years ago
use few turns of very thick wire a 9 V is not anywhere close to that. 500 9Vs in parallel maybe
11 years ago
batteries? *pfftt...
Try re-winding a MOT (microwave oven transformer) with about 3-4 turns or REALLY thick wire, I've seen people get Hundreds of amps out of it
see https://www.instructables.com/id/Homemade-Spot-Welder/?ALLSTEPSJust look at the transformer.
if thats too much of a hassle you can use a PC (AXT) PSU like https://www.instructables.com/id/Computer-Power-Supply-to-Bench-Power-Supply/ And make it https://www.instructables.com/id/Convert-an-ATX-Power-Supply-Into-a-Regular-DC-Powe/?ALLSTEPS
hope i helped
12 years ago
9v batteries are piss poor for high current applications, you would be better off with 2xNiMH "D" cells or a small Ld-Acid battery, You can buy singly cell Ld acids that put out 2v with whatever A/h your prepared to pay for. As for using a transformer with a battery it's more trouble than it's worth, you would basically be building a small inverter, you can get single chip voltage regulators if you want to control the voltage but they arn't much good for high current applications.
Answer 12 years ago
Ok...where can I find the MiMH batteries, or the Ld ones?? I realize I'd be building a small inverter, which I think would be fun if I got it right. A voltage regulator wouldn't increase my amperage would it?? I have never used or seen one, so I don't know.. Thanks a lot : )
Answer 12 years ago
rechargeable AA batteries are nimh car battery is ld. there are smaller lds (sealed lead acid battery) you understand the inverter and volt reg part correctly
Answer 12 years ago
Thanks again : ) Where would I be able to find a smaller ld battery, like you suggest?? I'm assuming it's going to be rather expensive, heavy, and can't be salvaged from anything I could find easily?? Thanks!
Answer 12 years ago
they are used mostly in computer UPS / some emergency lighting fixtures / other emergency related stuff they can give about 10 - 40 A (depends on exact battery) without damage (they can much more but will have short life) they dont have very much life in them especially if you discharge them a lot. (most are designed to wait all their life to emergency that never happens). and you need to bother about charging etc its better to use line powered power supply like the microwave transformer or computer power supply
Answer 12 years ago
sorry i missed this one : ) thanks! 40A would be amazing.. I think I've got what I need, thanks a lot!
12 years ago
use a computer power supply. you have 3.3 / 5 / 12 V DC at tens of amps each
Answer 12 years ago
Thanks : ) would that be from 120v AC though?? I'm a noob at all the circuiting stuff...
Answer 12 years ago
yep it plugs to ac
Answer 12 years ago
Thanks! But I was thinking portable : )
Answer 12 years ago
then go for sealed lead acid batteries (what pyper called LD)
Answer 12 years ago
ok, thanks : )..from what I'm seeing, they're pretty expensive, thanks though!
