MIcrochip - ''can't open include file''
Hi ALL!
Please help me to find the bug!
Yesterday I did the new instalation of the MPLAB X last version v3.45 after deleting the old.
I did the following tutorial to find bugs in the compilation and chip injection:
https://www.youtube.com/watch?v=mUofSucHx_E
The problem apear when I try to inject the software in the chip with the PICKIT3 when before nevar did so new problem.
Today I reinstall all the software again two times and nothing pass than the same error.
Script aded here of the only both files.
Thank you in advance.
Me
Output feedback START
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Users/Toshiba/MPLABXProjects/PIC18F2550_LED_Flashing.X'
make -f nbproject/Makefile-default.mk dist/default/production/PIC18F2550_LED_Flashing.X.production.hex
make[2]: Entering directory 'C:/Users/Toshiba/MPLABXProjects/PIC18F2550_LED_Flashing.X'
"C:\Program Files (x86)\Microchip\xc8\v1.38\bin\xc8.exe" --pass1 --chip=18F2550 -Q -G --double=24 --float=24 --emi=wordwrite --opt=default,+asm,+asmfile,-speed,+space,-debug --addrqual=ignore --mode=free -P -N255 --warn=-3 --asmlist -DXPRJ_default=default --summary=default,-psect,-class,+mem,-hex,-file --output=default,-inhx032 --runtime=default,+clear,+init,-keep,-no_startup,-download,+config,+clib,-plib --output=-mcof,+elf:multilocs --stack=compiled:auto:auto:auto "--errformat=%f:%l: error: (%n) %s" "--warnformat=%f:%l: warning: (%n) %s" "--msgformat=%f:%l: advisory: (%n) %s" -obuild/default/production/main.p1 main.c
main.c:10: error: (141) can't open include file "main.h": No such file or directory
make[2]: *** [build/default/production/main.p1] Error 1
make[1]: *** [.build-conf] Error 2
(908) exit status = 1
nbproject/Makefile-default.mk:100: recipe for target 'build/default/production/main.p1' failed
make[2]: Leaving directory 'C:/Users/Toshiba/MPLABXProjects/PIC18F2550_LED_Flashing.X'
nbproject/Makefile-default.mk:84: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Users/Toshiba/MPLABXProjects/PIC18F2550_LED_Flashing.X'
make: *** [.build-impl] Error 2
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
BUILD FAILED (exit value 2, total time: 606ms)
Output feedback END
JAVA are in the last one version up to date
My system:
SATELLITE L50-A-1F2
Windows 8.1 64-bit
4th generation Intel® Core™ i7-4700MQ processor with Intel® Turbo Boost Technology 2.0
39.6cm (15.6”) , Toshiba TruBrite® HD TFT High Brightness display with 16 : 9 aspect ratio and LED backlighting
Hard disk 1 TB
Shining silver finish with stripe pattern, black keyboard
8,192 (4,096 + 4,096) MB, DDR3L RAM (1,600 MHz)
NVIDIA® GeForce® GT 740M with CUDA™ Technology and NVIDIA® Optimus™ Technology
maximum life : up to 4h00min (Mobile Mark™ 2012)
weight : starting at 2.40 kg
W x D x H : 377.5 x 244.0 x 25.95 mm
