105Views5Replies
Author Options:
Make a spring Answered
Dear all.
I would like to make a spring 8mm diameter 100 mm long with 18 gauge galvanized wire (needless perfect) . Please could you help me to know :
It's must make   heat treatment  before or after on the finished spring .Thank you so much
Tags:Springs
Downunder35m
Downunder35m
4 years ago
You don't want to use galvanised wire to start with unless you want to burn the spring away while hardening it.
In fact you need
a) a suitable wire
b) the means for proper heat treatment
You can get ready to use spring wire and it needs to be wound up smaller than what you require as it coils back.
IMHO it is far too much hassle to make your own springs unless it really is the only option and as siad then I would go for spring wire instead.
lam
lam
Reply 4 years ago
Dear Downunder35m
First thank you for your help ,I am sorry for my question not clear. I want to use galvanized wire ( not piano wire) for make a springs but I don't know :
- I must : first make heat treatment wire before or after on the finished spring for more springy .Thank you again
Downunder35m
Downunder35m
Reply 4 years ago
Just to be clear here:
a) galvanised wire is usually not suited for spring use
b) it does not matter if you heat treat before or after as the galvanised wire will burn
If you need it galvanised than it will fail anyway.
The gal will break and crumble when the spring is in use as it is very brittle.
Better option would be to passify the wire with a phosphor coating or to simply use wire that is suited for your needs.
lam
lam
Reply 4 years ago
Dear Downunder35m
Many thank you . Learning more from you Thank you again for your concern and advise me Best regards
Yonatan24
Yonatan24
4 years ago
Google "How to make a spring"
