94Views8Replies
Author Options:
Make image and project it? Answered
Hello everyone, I wanted for a while to make an image so that I can project but don't really know how to do it until recently I got this small like flashlight that actually projects an image.  Does anyone knows how to do it and the parts needed to build it. thanks
rickharris
rickharris
Best Answer 5 years ago
You can do this fairly easily
You will need:
A bright light source, perhaps a bright LED
A suitable transparent image
A convex lens
Arrange as in the picture below and position the lens to give a bright sharp image on the screen.
The second image shows how to use a non-transparent image using slightly more complicated construction
You need:
A box with a glass or clear plastic top
1 or 2 bright lights
A mirror
A convex lens
Arrange as in the second image below.
The light shines on the mirror and is reflected onto the image through the clear box top
The light reflects off the image back down to the mirror and out through the lens
The image will be a little dimmer then direct projection through a transparency but quite visible.
Chamburn
Chamburn
Answer 5 years ago
Excellent I will start asap to look for the parts and hopefully but the end of this month I should have a working prototype. thanks for the information
rickharris
rickharris
Answer 5 years ago
Your welcome. pick a best answer to close the question :-)
-max-
-max-
5 years ago
Just stick a big magnifying lens in front of your phone screen. Tada, el-cheapo phone projector!
Chamburn
Chamburn
Answer 5 years ago
Lol never thought of that but I am looking for something which is very simple.
-max-
-max-
Answer 5 years ago
Umm, I don't know how much simpler it can possibly get! :) That method should work with any well illuminated photo, screen, etc.
You might want to study up a little on "virtual" and "real" images, and optics in general. I am not the expert in optics, but I recall vaguely from physics classes that Virtual images refer to basicly images that exists "inside" lenses and mirrors. Those are what you see in a mirror, or through a telescope or something. The image existing on the surface of a lens is not really there, same with mirrors. Hence "virtual." However, to turn this into a real image, that is, one that can be projected, you need additional optics.
The link below is to khan academy, that that is his playlist all about optics and cool stuff.
https://www.khanacademy.org/science/physics/geomet...
Downunder35m
Downunder35m
5 years ago
You get them for cars too, a LED lamp to stick on your door frame and when you open the door it shows a logo on the street.
Look up how a film or dia projector works, it is the same thing only that the image used is quite tiny.
Chamburn
Chamburn
Answer 5 years ago
Yes I know about the car projection ones but I want to build one of my own. Thanks for the search criterias.
